Is this NEW? Or did it just fail spontaneously after working for awhile? http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641 It describes a way to possibly fix your remote or at least prove it works or doesn't. Find new or replacement remotes: http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861 or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
The sub woofer works fine and is hooked up correctly. The receiver sub out, to LFE and the receiver sub is set to the on position. I unpacked my DSW microPro 2000 sub woofer and the remote for that one doesn't work either. Both devices are set for 230 voltage and seem to work fine. Both sub woofers remotes never worked from day one, even with new batteries and the IR sensor isn't blocked.
And the part about removing the plastic tab that blocks the batteries????? Did you do that?
Do I have to ask if you did EVERY thing I recommended in my first post?
http://remotes.com/remotes/servlet/rs?a=...
I gave you the wrong link...
Sure did on both remotes.
I did everything you suggested in the first post and the part about the plastic tab was removed. Still no response from either remote on my 500 or my 2000 sub-woofer.
