Will not heat we replaced both elements but still no hot water rheem model no.82v522marlene we suspect we had a power surge during last storm because the furnace went out also at the same time
Re: Will not heat we replaced both elements but still no...
Hi I suspect your thermostat will have also been damaged if you had a surge I always replace thermostats at the same time as the elements
Also check the wiring as sometimes surges can melt the copper core of the wiring, but be careful always turn off the power first before any electrical works!
Electric water heater is fully repairable unless it is rusted out. All 2-element tanks are 240Volts.
If you have NO hot water, then suspects are 240Volt circuit supplying only 120V, reset button is tripped out on upper thermostat, bad upper thermostat, bad upper element. If elements were not completely covered with water when power was turned on, then elements will instantly burn out. When filling water heater tanks, open bathtub spout. Wait for water to come out full stream. Then open TP valve on water heater for a moment to remove last of air. Then turn on electricity.
1) All tankless water heaters require voltage to operate electronic sensors and circuit board. This is true for gas and electric tankless.
2) Check that circuit breaker is not tripped. Push circuit breaker all the way one direction and then all the way back other direction.
3) There are fuses located inside the tankless unit, so check your manual for location of each fuse. Manual is filled with useful maintenance and troubleshooting steps.
5) If you had nearby lightning strike, I don't know if your tankless is protected from surge.
I recommend whole-house surge protector for tank and tankless water heater electronics,
and household circuits. Surge protection is installed in main breaker
box, and is replaced after each surge event. Separate protection needed
for co-ax TV satellite, co-ax surge protection can be found on some ordinary power strips. http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
B) Water heater has some hot water. That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event. http://waterheatertimer.org/How-it-works.html
C) That leaves 4 suspects that cause lower amount of hot water.
3) Burned or shorted wire located between upper and lower sections of tank. Turn off power. Open covers on side of tank. Remove insulation.
Inspect parts for signs of high heat and burning. Especially check
lower element. Tighten any loose wires. Replace part that shows signs of
burning. Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature. http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help. Also take advantage of fixya phone service. For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005. Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front. Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects: C) Water heater has some hot water. This tells us upper element is working. And that water heater electricity is working. And that reset button is not tripped. And that heater is not experiencing run-away overheating event.
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning. Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
Age of Rheem water heateris first 4 digits of serial number located on side of tank: for example 0705 means July 2005. Serial number also shows model number & wattage of elements.
B) If cold outside temperatures are not to blame, your water heater may have a bad thermostat or bad lower element.
C) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front. Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects: D) Water heater has some hot water. This tells us upper element is working. And that water heater electricity is working. And that reset button is not tripped. And that heater is not experiencing run-away overheating event.
3)
misread tank temperature. Rheem element
Lower element can be burned out and still read 230V across screws
1) We know thermostats are working because elements test 230V. 2) We know upper element is working because tank has some hot water. If upper element is burned out, tank will have no hot water. http://waterheatertimer.org/How-it-works.html
look for a badly connected power line ont he bottom element, or any connection upstream of the power terminals. voltage readings usually drop to that range when you only have one side of the 220v circuit connected.
Remove power from WH Remove heating element covers and, insullation you will see two screws and, a red button (reset) for each element; push the button for each element to reset them; put everything back repower and, test. If the problem is still there: Remove power, test element screws with a meter set for resistance; if no continuity drain WH and, replace element(s)
