The cause of the alarm is one of the main components needed to start the system.
1st, try reseating RAM. Also try removing all but 1 stick of ram and rotate the remaining sticks to see if it is a defective RAM
Remove all add-on cards leaving just the mother board. It should start with no boards except Video if it is not built-in. Also disconnect all the drives and other peripherals.
Could be a bad power supply. Test all the outputs or replace.
The last item would be the processor.
Best of luck and post if you figure out which is bad.
Jim
