Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57" Rear Projection Cinema
6ya staff
SOURCE:
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: TV picture scrambled and getting worse
This can be a fault in the tuner, IF, or primary part of the video processing. With age and use some of the parts, and especialy capacitors, in these sets can become thermo sensitive and unstable.
To service these types of faults can be very time consuming. On top of this would be the cost of the parts.
Considering the age and type of set that you have, I would suggest that it is time to be looking for a new set.
Jerry G.
Posted on Apr 21, 2008
Vista Electronics
  • 1694 Answers
SOURCE: 57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Posted on Apr 25, 2008
Anonymous
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Posted on Apr 30, 2008
premtech
William Rayburn
  • 934 Answers
SOURCE: 50HDX82 rear projection Flicker/Fuzzy and Vertical Purple Lines
The hyper module itself is not an expensive repair about $70 to $100.00 dollars. The tech will simply be replacing about a dozen 16v/10mf smd caps and re-installing it on the signal board. But that doesn't address what he has to do to get to it and get the hyper board off and back on the signal board and that is a bit time consuming.
What I would suggest is to call around to the various shops and ask what they charge for the hyper module repair and see if you can get an off the cuff estimate for around $250.00 dollars.
If you need help finding some reputable shops try TVrepairpros.com for help in finding some of the best technicians available.
Bill
Posted on Jan 09, 2009
David Tolond
  • 2501 Answers
SOURCE: 57" Toshiba projection TV randomly turns itself off and on
Look for loose connections in the power supply (plug, socket).
Posted on Feb 25, 2010
What would cause a projection screen tv (toshiba) to have to warm up when turned on? the picture flutters and is unviewable for 6 to 7 minutes
The Hyper module needs replacement. There were repair kits available for the hyper boards several years back the capacitors ( surface mount) need replacement
Jul 01, 2011 | Toshiba 57H81 57" Rear Projection...
My TV is about 9 yrs. old. Lately, it seems to need to "warm up". The picture looks jagged or jumpy when first turned on, but improves after a few minutes. Can this be fixed?
This problem stems from defective surface mount capacitors on the "hyper module" (which is no longer available as a part). The capacitors can be replaced by a technican with good soldering skills however and is accompolished by using 105 degree type PC style or 10 uF/16 volt SMD caps. All 11 of them must be changed for a lasting repair. They are at locations: CX 178,221,230,241,250,261,270,514,541,670 and C5030.
Jan 30, 2011 | Toshiba 57H81 57" Rear Projection...
I have a Toshiba 57H81 57 in. Rear Projection Television. The picture started having "squiggles" in it, which at first went away after the T.V. "warmed up". Now they appear to be...
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replace on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Toshiba 57H81 57" Rear Projection...
TOSHIBA 57H82 TV Blurry for 15 minutes till warms up
This is a model first sold 2002.
They have a history of the Hyper board failing. Usually noise or lines in the picture and the warmup time gradually gets longer and longer.
This board processes all signal from all inputs inside the set and is no longer available from Toshiba.
The only way to get one is from a national company called PTS Electronics who rebuilds or repairs them--cost for rebuilt board is about 220 plus shipping and part number for this model is:
Part Number23148024
I have a service bulletin with photos of the board on my computer.
It is a financial decision, not a job for the average do it yourself person to attempt.
Let me know if you have questions or need help.
SD TECH
May 03, 2010 | Toshiba 57H82 57" Rear Projection...
My Toshiba cinema series HD separates the red & blue color.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
Feb 25, 2010 | Toshiba 57H82 57" Rear Projection...
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
