Dell Inspiron 1525 Notebook Logo
Posted on Mar 06, 2011
Keys typing wrong numbers and characters - Dell Inspiron 1525 Notebook
Anonymous
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Mar 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
29
Questions
Helped
7529
Points
96
You must have activated the NumLK (Number Lock) to deactivate it press the 'Fn' Key with the 'NumLk' Key which is usually 'F11' Key in certain notebooks.
How do I type accents on a laptop without a secondary numeric keypad?
In order to type accented characters, you'll need to know the ASCII code of that character. You can check that out in the character map. This can be accessed in the following way:
  • Click the Start button
  • Click All Programs
  • Clicking Accessories,
  • Click System Tools
  • Click Character Map.
Once you have the character map open, you can just highlight the character that you want, and the ASCII code will be displayed on the 'Character map' window.
In order to insert the character, go to the textbox where you need to insert it, hold down the 'Alt' key on the keyboard and type the number on the numeric keypad.
In case of a laptop, you'll need use the numbers on the numeric keypad. But there's no separate numeric keypad on a laptop, instead, the numbers are arranged on the same keys as the letters. They're separate from the numbers on the top line.
tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 • Cell Phones
tip
How to use Blackberry as a modem to acces internet?
3answers
We i installed mirocsoft office, outlook, powerpoint etc... they said i need my product key code and i saw that the product key was on the bottom but wen I typed the numbers an letters it said it was...
Hi
Try this is to activated your microsoft office 2007
For full setup --- VB48G-H6VK9-WJ93D-9R6RM-VP7GT
For single setup --- HCFPT-K86VV-DCKH3-87CCR-FM6HW
1helpful
I cant acess microsoft word to do my research its asking for the 25 character product key i entered the one at the back but it says its incorrect.
hi there,
Please make sure that you have typed the license number correctly. Usually it should be 5 characters then a ( - ) hyphen. If it still says incorrect you might want to try contacting microsoft from the phone number thats listed on the packaging because something must be wrong with that license number.
My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
1helpful
Asus X58Cseries with Windows Vista Basic has $ sign on 4 key but no pound sign. Any way of getting it? If not, I can live with it but would like to know either way.Cheers, Linda.
I'm an Asus X58C user in the UK and my keyboard is the same. I've not found an easy solution. The only way I can insert a £ character is this. Place your coursor where you want the character. Turn Numbers Lock on using the blue Fn and NumLk keys. Hold down the Alt key and then using the blue numbers keys type 0163. Release the Alt key and the £ character will appear. Turn Numbers Lock off using the blue Fn and NumLk keys again. Its laborious but it works, its how I typed it here. I also found out that if you hold down Ctrl and Alt and then press the 4 key, you type the euro character €. Hope this helps
Having troubles typing. Wrong characters com up...symbols display instaerd of letters. I did something.
just check the either ur keys wil be misplaced or goto keyword through control panel n edit the keys
The keyboard characters does not correspond to what appears on sc
Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
2helpful
Keyboard typing wrong characters
turn off the keylock on boot- this is an option in the bios. also you might be able to use the fn key and turn it off manually
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
