Dell 924 All-in-One InkJet Printer Logo
Posted on Mar 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting the following error message: Black/photo cartridge missing
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 75 Answers
  • Posted on Mar 07, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
75
Questions
0
Helped
21331
Points
114
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
4 Related Answers
Anonymous
  • 82 Answers
  • Posted on Nov 06, 2009
SOURCE: My dell photo 966 says'left cartridge missing
the contact that detects the left cartridge may be dirty or not functioning at all. clean it with cotton and 100\% isopropyl alchohol then reinsert the cartridge. if it still doesn't work, it must be replaced.
pineworks
Clive
  • 4362 Answers
  • Posted on Apr 28, 2010
SOURCE: installed a black ink cartridge and the printer
Hi there Error 50c
Can only gave it a try.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
puertobori
  • 7733 Answers
  • Posted on Nov 21, 2010
SOURCE: When I replaced the black cartridge on my HP 6500
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.Post / thumbs / testimonial are welcome!
Anonymous
  • 3344 Answers
  • Posted on Aug 12, 2011
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: I have inserted a new black ink cartridge (34) and
    Make sure you are inserting a genuine Lexmark cartridge. Try to insert a different known working cartridge, maybe your old black cartridge, to determine if your new cartridge is faulty. If inserting your old black cartridge gives you a message saying "very low ink" or something to that effect, then most probably there's something wrong with the new black cartridge. Have it replaced with a new one from the store where you bought it from. You may also contact Lexmark Technical Support Center for assistance.
    Missing cartridge error message
    Please try the following article. It may he resolve you problem.
    Print cartridge missing
    Other wise Follow Us For
    HP Printer Support
    INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
    Hi there
    You should always mention the printer model as well as what operating system you use.
    This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
    Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
    Your print cartridge has shorted.
    1. Power off your All-in-One and unplug it.
    2. Plug in your All-in-One again and turn it on.
    3. Uninstall and then reinstall your cartridges.
    4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
    Error: Black Cartridge Missing
    The black cartridge is not installed. (Install cartridge PN 82)
    Error: Color Cartridge Missing
    The color cartridge is not installed (Install cartridge PN 83)
    Cartridge Error
    Complete the following instructions:
    1. Power off your All-in-One.
    2. Use both hands to lift up the scanner unit until the scanner support holds it open.
    3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
    4. Remove the color print cartridge.
    5. Lower the scanner unit until it is completely closed.
    6. If the error message reappears, replace the black print cartridge with a new print cartridge.
      If it does not repeat steps 1-3 and then go to step 7.
    7. Reinstall the color cartridge and remove the black print cartridge.
    8. Lower the scanner unit until it is completely closed.
    9. If the error message occurs again, replace the color cartridge.
    10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
    11. Lower the scanner unit until it is completely closed.
    12. If you receive the error message again, replace both cartridges.
    Hope it helps
    Andre
    1helpful
    I have inserted a new black ink cartridge (34) and get an error message 'left cartridge missing, insert black or colour photo cartridge' have peeled label off and reinserted several times but still...
    Getting error code 2200 on Lexmark P6250 Photo All-In-One InkJet Printer. Programme asked to refer to user guide. Error code not in user guide. Unplugged printer while on. Restarted PC then replugged...
    hi
    here is what i have found -- follow to all instructions accordingly
    although its for another model, these isntructions apply according t their techsupport i spoke with
    .Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
    Did the error message return?
    Yes: Continue to step 2.
    No: Attempt a test scan. If the error message does not reappear, the error is resolved.
    2.
    Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
    Yes: Continue to Contacting Lexmark.
    No: Continue to step 3.
    3.
    Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
    Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
    No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
    4.
    Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
    Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
    No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
    here is where i found the error http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&question=2200 error#1
    hope this helps -- God's speed
    2helpful
    Cartridge Error 50C consult user guide. I
    Cartridge Error
    Have put in a new colour cartridge but the note on the printer comes up error 50C
    Cartridge Error 50C
    Cartridge Error
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Error 50
    Is that an error code "Cartridge Error 50C" ? If so, see below....
    Cartridge Error 50C: Your print cartridge has shorted.
    Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
    Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
    Cartridge Error: Complete the following instructions:
    2helpful
    2answers
    Hp psc2410xi
    The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
    1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
    2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
      • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
        1. Clean the color cartridge contacts.
        2. Reinsert the color cartridge into the carriage and close the blue latch.
        3. Close the printer and wait 10 to 15 seconds.
        4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
      OR
      • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
        1. Reinsert the color cartridge.
        2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
        3. Clean the black or photo cartridge contacts.
        4. Reinsert the black or photo cartridge.
        5. Close the printer and wait 10 to 15 seconds.
        6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
    1. Remove and then reinsert the cartridge indicated in the error message.
    2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    6helpful
    3answers
    Error code 1203
    To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
    Top Dell Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Norman Weimar
    Norman Weimar
    Ngoro
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
