Question about Hobart Food Mixers
What kind of oil should I use in my Hobart 800 floor mixer? [email protected]
Posted by jdnwilk on
Justin Burnett
    Guru:
  • 257 Answers
Hello Jdnwilk,
In a Hobart L800 you use 140 weight gear oil in the head and 90 weight gear oil in the planetary. You should start with about 160 ounces and check the sight glass and fill until in the middle of the site glass after oil settles.
Thank you for choosing FixYa.com
Posted on Mar 06, 2011
How do i put back togeather Hobart 300-d mixer
http://www.hobartservice.com/Parts/
Go to this page and click on Hobart Smartparts System. Select Food Machines, Floor Mixers, D300 and you will eventually find parts breakdowns.
Feb 25, 2010 | Hobart D300 Stand Mixer
I HAVE A HOBART MIXER D300 ML#11627 I NEED TO KNOW WHAT KIND OF GREASE TO USE FOR TRANSMISSION,AND WHERE CAN I GET IT
Goto hobartcorp.com,create a username and then you will be able to find out what your looking for.I know that these mixers used oil when they where new but now changed to grease.Any ? let me know as im a hobart tech a repair these often.
Nov 19, 2009 | Hobart D300 Stand Mixer
Have an old hobart 140 mixer and i want to chang oil what kind of oil do i use
you need to replace it with a "FOOD-GRADE" mineral oil or FOOD-GRADE white lithium grease, you can get this from "Lubri-Plate" at their web-site
Nov 18, 2009 | Hobart D300 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Transmission oil
this unit uses grease if it is leaking out the grease has broken and needs replacing
Sep 09, 2008 | Hobart D300 Stand Mixer
Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Jul 24, 2008 | Hobart H600 Stand Mixer
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
736 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
