Question about Eclipse CLD2 MP3 Player
I sync music onto my mp3 player and it keeps saying no files
Posted by youngricky_a on
Esari
    New Friend:
Either there is an error with how the files are being placed in the device, such as shortcuts, or the files you placed are not supported by the device.
There should have been instructions that came with the mp3 player, try reading up on where the files need to be placed. Make sure you didn't change any folder names (or maybe you have to create a folder before syncing.) Also, doing a quick google search, I found that it supports .mp3, .wav, and .wma files. So be sure to check if the files you sync'd are the right format. (Right click the music file, properties, Type of file: ____) I can't imagine that being the problem, as most music is already in mp3 format.
Good luck.
Posted on Mar 06, 2011
  • 6pktogo Mar 13, 2011
    I was looking for answers to that same problem when I read one of the comments that stated you need to have the music all in the music folder and not in any sub folders that may have been created inside the music folder during your sync. Move them all out of the sub folders. Best and quickest I found was to cut and paste then go back and delete the empty folders. An album with 20 songs took 30 seconds to move. You can also copy and paste but it takes longer and then you need to delete the folder that is still full of songs so that also takes more time.
How do i download music to my mp3
MP3 players can only play music files in mp3 file format. You can download mp3 music files onto your computer and then copy them to your MP3 player.
For CD disks you need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Jul 02, 2011 | Sylvania Audio Players & Recorders
When i put music onto the mp3 player on the computer it says added b ut the player says no files what do i do now?
When you Connect your player to your computer, open windows media player. There should be a tab called sync. when you press it you should see your player on the right side of the screen. If not then there should be a button there where it says configure player. When you want to put a song in , just drag it into the space provided by windows media player. Then click sync on the bottom of the player. it should sync the music.
Dec 29, 2010 | Audio Players & Recorders
I went to the format thing on my device and then erased all my songs i draged the ones i want to keep onto the desktop and downloaded more to my desktop now when i sync them on it says its downloading em...
All you have to do to access the files and listen to them, assuming they worked before is access the menu, then select browse all music, you will find your music files there, happens to me. To see your files on the play list section of the mp3 player, Open my computer > Go to your mp3 player > Select the music files > Right click and click add to play list.
Hope I helped
Aug 20, 2010 | Memorex MMP8565 MP3 Player
Help!! My gogo gear keep deleteing by music oof
Disable auto-sync in Windows Media Player to solve the problem.
Disable Auto-Sync in Windows Media Player 11 – go to Microsoft's website for pictorial demonstration
Major Symptom: The Mp3 player is adding (or deleting) songs that I don’t want onto the player
Major Solution:
Open Windows Media Player WITH the mp3 player connected
Move the mouse cursor over to the Sync tab
Click on the tiny black arrow underneath the word “Sync” to bring down a drop-down menu
Select Set Up Sync (this option will not appear if your mp3 player is not connected to the computer)
Uncheck box that says "automatically sync files to device"
Click OK to finish
Voila! You are now set up for manual sync instead of auto-sync.
-Tha Mp3 Doctor
Nov 13, 2008 | Philips SA5125/37 MP3 Player
My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
Sep 11, 2008 | Philips GoGear HDD1830 MP3 Player
MP3 Player wont let me listen to music it says it has on it
If you already formatted the player itself, the songs itself may be in the wrong format. This player doesn't read iTunes files, for instance - it will look like they have transferrred, but you will not be able to play them.
May 26, 2008 | SanDisk Sansa m230 MP3 Player
Music & memory loss
so i guess ur done with it..
May 01, 2008 | Sony NWZ-B103FBLK MP3 Player
Syncing music to motorola k1m mp3 player
Download on to your pc free of charge a product by NCH software called, Switch sound file converter it converts all your music to MP3 format very easily.
regards Breezey47.
Mar 18, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Downloading music trouble
After you've downloaded the music files you want from Lime wire put them in your music folder on your computer ,then you need to sync your MP3 player through windows media player. plug in your mp3 player then open windows media player, on the top right there is tab says sync. click on refresh devices and your mp3 player should show up on the right window pane in windows media player. From there you can drag all your music onto it and press sync!
Hope this works
Dan
Feb 22, 2008 | iLO MP3 Player
Why isn't it going onto my Mp3?
stay on limewire, go to Windows Media Player and click Sync.It should say something in the corner like,'drag items here'.then go back to limewire,click and hold onto the songs u want on ur Mp3 and drag them to the 'drag items here' spot. when ur done getting all the songs u want,click 'Start Sync' and ur songs will be transfered to ur Mp3!
Apr 25, 2007 | iLO (2 GB) MP3 Player
Eclipse CLD2 MP3 Player Logo
302 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
john h
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
