First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Testimonial: "Thanks a bunch!!!! I trust your judgement"
Yes you will BUT do not connect more speakers than two 8 ohm units so connected to an output jack of the amp rated at 4 ohms. You will LIKELY want to connect the monitors to one of the jacks and the mains to the other so you can have independent control of monitor levels different than the mains.
