Question about RCA RCR311B Remote Control
How do I reset my remote, it fell and the batteries came out so icant use it because I need to reset it HELp
    New Friend:
  • 3 Answers
With the batteries out, press and hold down the #1 button on the keypad for 60 seconds. You may have to do this 3-5 times to clear the remote. Insert the batteries and begin reprogramming.
Posted on Mar 06, 2011
Empire Comfort Systems fireplace remote control not working since fell off table. Fireplace still works fine manually and the batteries in both the remote control and receiver were fine before it fell. ...
I assume you've tried removing and re-seating the batteries in the remote. If this doesn't reset the remote the fall most likely broke a component or solder point on the circuit board. If all else fails you can try opening the remote and making sure no wires are broken. Look closely around the battery contact points. Often when a remote is dropped the weight of the battery can cause damage to that area.
May 02, 2015 | Home Security
How do I reset the remote? It fell on the floor & the battery came out & now does not work.
Most remote controls will reset itself, when the battery is taken out of its compartment. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 06, 2014 | Televison & Video
I have a 1997 vw cabrio. i replaced my battery n when i hook up the battery my alarm goes off n my driver side lock cylinder fell out how do i disarm my alarm?
You need to bypass the alarm if you do not have the remote to disable it and the key lock fell out. I have posted multiple times about how to bypass the stock alarm and still have everything work. If you need any help on doing this please feel free to message me.
Mar 07, 2014 | 1997 Volkswagen Jetta
Ir out
Check and replace its infrared emittor LED.
Feb 28, 2013 | Universal MX-900 Remote Control
Remote control won't work after fall
http://www.oneforall-na.com/list_codes.php?db_value=access4&remote_choice=URC3220
This will give you all the codes you need!
Jan 07, 2010 | RCA Universal Remote Control
Philips remote control needs resetting to work with Panasonic TV
Hi Shirley,
Check this site, they normally have code lists for a huge number of remotes:
Remotes
Dec 17, 2009 | Philips Universal PH301S Remote Control
The Denon RC 1048 fell off couch and will not work now. I have replaced the batteries (to try and reset it), but the receiver seems to not "communicate" with the remote now. Any ideas?
It is possible that when it fell that the connectors on the infrared might broke loose therefore not sending a signal to your receiver. Easy way to check that when you press buttons on your remote does the red light come on or not? If not then take remote apart and re-solder connection. If the light comes on try resetting your remote code to the receiver that you have. You can find a list of remote codes in your user manual or online at (http://www.usa.denon.com/ProductSupportAndArchives.asp) just find the model number of your receiver and get the .pdf file from them.
Apr 14, 2009 | Denon PMD750 Grayscale Remote Control
Remote not working need replacement
kindly mention the brand and make of your remote if you need help and how old it is.good luck.
Apr 09, 2009 | Audio Players & Recorders
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
RCA RCR311B Remote Control Logo
110 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
