Question about Toshiba Satellite A100-S8111TD Notebook
HOW DO YOU TURN LIGHT BENEATH KEYBOARD ON TOSHIBA A660/07T
Posted by daitken207 on
Beymer
    New Friend:
  • 20 Answers
I'm not sure what model you have I do not see a A660/07T.
Here is a listing of the different models that have an LED Backlit keyboard. http://us.toshiba.com/computers/laptops/satellite/A660/available-models?EXTRAS=LED+Backlit+Keyboard&SERIES=A660&SUBBRAND=Satellite%26reg%3B&Ns=pUnitsSold'1&sms_ss=email&at_xt=4cddcae4e07d677f,0
Posted on Mar 06, 2011
Anonymous
    Sergeant:
  • 167 Answers
Only media buttons are backlit, the keyboard itself is not.
Posted on Mar 05, 2011
Keyboard back light won't turn off i have a
It's probably either in suspension or connected to the charger. It's not a problem.
Aug 20, 2013 | Toshiba Qosmio Computers & Internet
Can not pair my Vibe VE 1089 bluetooth keyboard with my iPad mini.
The manual for the Vibe iPad Bluetooth Keyboard Folio is completely wrong. To turn on the keyboard, press and hold the button above the word "charge" in the upper right hand of the keyboard. Blue lights beneath the word "power" and beneath the Bluetooth symbol should flash. In order to pair the keyboard, press the same button above "charge" and hold for a shorter time. The light beneath the Bluetooth symbol should flash.
Feb 06, 2013 | Apple Ipad I-pad
I have a Vibe bluetooth keyboard folio for ipad mini--can't find ON switch--nothing on bottom right! How do I turn it ON?
Feb 05, 2013 | Cars & Trucks
Screen wont come on, on my Toshiba laptop computer
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel.
Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on.
If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective.
If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps.
Jan 15, 2013 | Toshiba Computers & Internet
Keyboard is not working in mobile
change the rubber pad beneath the keyboard or keep one light film of tissue paper beneath key board
Dec 03, 2010 | T-Mobile My Touch Cell Phone
Some keys on my keyboard dont work
The keys may have dirt and debris beneath them or could be damaged.
Go to Start, select Control Panel and then type keyboard in the search box on the upper right side. A new window will open; click on Keyboard and select either option from the menu to verify the functionality of your keyboard...
Jul 19, 2009 | Toshiba Tecra M2 P-M 1.7Ghz, 512MB, 60GB,...
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
