Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Ti-84 Plus help!! - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Posted by jkapples10 on
  • 1 more comment
  • kakima Mar 05, 2011
    Do you have a specific question or problem? We can't help you if you don't ask a question.
  • Filipe Polido
    Filipe Polido Mar 06, 2011
    Help with WHAT ?
  • answers8 Mar 06, 2011
    What is the problem
Math Cheetah
    Scholar:
    New Friend:
  • 22 Answers
It seems like you're just starting off. And....
....The best thing you can do is begin hacking away at different buttons until you figure out what certain things do. I guarantee, that you will discover some pretty amazing things within the TI-84.
Compared to other calculators, the TI-84 is pretty user-friendly. Don't be scared.
In my opinion, Texas Instruments' customer service is one of the best in the nation. Call them for specific questions, they're great at the basics but not-so hot at the advanced. Friendly & helpful people, though.
Posted on Mar 08, 2011
Is it possible to change the faceplate of the TI-84 Plus calculator?
Yes, you can change the faceplate of the TI 84PLUS Silver Edition only, not the TI 84 Plus. Face plates are available for purchase at the TI online store.When you go the online store, select the country, then the calculator model. You will find them under accessories for the TI 84 Plus SE.
Aug 15, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 calculator lost its cover for the batteries. Since then it sometimes can't turn on or show anything when I push the button "on". But sometimes it still can work. But because I havent...
Hi twylazhangzh,
Sound like your Ti 84 Plus is really over loaded and, can't function properly. You can fix that by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer just keep following my instructions below.
First, you need to download and, install Ti Connect to your computer. If you don't need any help installing Ti Connect goto Procedure 1.
If your computer's OS is XP or Mac and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my XP or Mac OS". Just follow Procedure 1 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
If your computer's OS is Windows 7 and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my Windows 7 OS". Just follow Procedure 3 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
Procedure 1 to installing Ti84 Plus 2.55v. MP OS
1). You can also get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install.
Next, the Ti Device window should pop up and, highlight the port when found that your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
When ever i turn on my ti-84, it says waiting..... PLease install operating system now.
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
Installing new OS
Hi mcniester,
If you need to install Ti Connect software, goto the paragraph (1) below. If you do not need to install Ti Connect software goto the paragraph (2), "Procedure to installing the newest Ti 84 Plus OS 2.35v."
1). You can get the latest copy of Ti Connect software by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti Connect software" At this Ti site under "View: Connectivity Software", Click, "the OS link that applies to your computers operating system". Next, click the Download Item, "Ti Connect software for ....OS". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti Connect software for ....OS will be download to you. Click, "OPEN" and the software will start installing. You will have to click "Next" a few times but, it install pretty fast. Once the Ti connect software has successfully installed follow the instructions to the
"Procedure to installing the newest Ti 84 Plus OS 2.35v." below.
2). You can also get the latest copy of Ti84 Plus 2.35v OS and guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.35v. OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system download to you. Click "SAVE" And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed.
Link your computer and calculator with the USB cable or Direct Black Link cable that came with the calculator. Next, drag the Ti 84 Plus OS 2.35v that you copied to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti connect" icon on the desktop. Click, "Continue" and, the new Ti 84 Plus OS 2.35v will begin to install. The Ti Device window may pop up and, click on to the port your Ti 84 Plus is using, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 84 Plus OS 2.35v will be installed.
Jan 06, 2011 | Texas Instruments TI-84 Plus Calculator
Where do I find the comma button on the TI-84 siver edition?
The comma is located on top of number 7 key.
See page 5 on teh user manual to learn how to operate the keyboard on a TI 84 Plus:
TI-84 Plus TI-84 Plus Silver Edition Guidebook
Mar 16, 2009 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Feb 23, 2009 | Texas Instruments TI-84 Plus Calculator
Waiting Please Install Operating System Now.
i finally fixed my calculator~
1. if you have a ti 84 plus silver, plus, or just ti 84, find a friend who has either a ti 84 plus silver, plus, or just ti 84. (as long as the number is the same)
2. link the two calculators together
3. using your friends calculator, press the [2nd] and the one next to alpha [x,t,o,n]
4. go all the way down to [send os]
5. send it to the other calculator and your problem should be fixed
Aug 27, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
103 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Scoee Scoffer
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
