Question about Texas Instruments TI-84 Plus Calculator
Just bought a ti 84 plus and it wont turn on pls help
Posted by xstream21 on
  • kakima Mar 05, 2011
    First, make sure the batteries are good and inserted properly. If it still doesn't turn on (or appears not to have turned on), try adjusting the screen contrast. Turn the calculator on (or at least press the ON key). Press and release the 2ND key, then press and hold the up-arrow key and see whether the cursor appears in the upper-left corner of the screen. Does it? (If you go too far and the entire screen turns black, press and release the 2ND key then press and hold the down-arrow key to lighten the screen.)
Filipe Polido
  • 123 Answers
Double check batteries and polarity first. If this doesn't help, return it to the store, you have a DOA (dead-on-arrival) machine. They're obligated to replace.
Posted on Mar 06, 2011
Ti 84 plus calculator wont turn off
Hi
its possible that the second key is it working
if this is the case this problem can be fixed Let me know if you want to fix the calc
May 31, 2012 | Texas Instruments TI-84 Plus Calculator
Just bought the ti84 plus and it wont turn on pls help thanks
Try changing the batteries located on the bottom backside. Otherwise there is not that much too it.
Good luck and please rate this comment if you find it useful.
Thanks.
Mar 05, 2011 | Texas Instruments TI-84 Plus Calculator
I jus bought a TI-84. when i turned it on it said RAM cleared. now there's a blinker on the screen. every time i press a button, nothing happens. whats wrong with this brad new calculator
You need to re-install or, update the Ti 84 Plus OS. Since you just bought the calculator it is unusual that it is already to that point of clearing the RAM. You can connect a computer and your Ti 84 calculator together once you downloaded and, installed Ti Connect software on the computer. That way you can use the Ti OS Downloader that comes with Ti Connect software to install the newest Ti 84 Plus OS. Or, if you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84.
Get this problem fixed as quick as you can. You do not want your OS to fail any more than what it already has. If you can not find another calculator to connect too, then you can connect through your computer. You may have a long road ahead of you getting the Ti Connect software and, drivers working right. Just remember to come back to your posting here and, post a comment of what ever is failing. This will notify me right away and, I'll walk you though it if necessary.
Jan 12, 2011 | Texas Instruments TI-84 Plus Calculator
My ti 84 plus silver edition wont turn on. I
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If that doesn't work, add a comment to this post and we'll go from there.
May 31, 2010 | Texas Instruments TI-84 Plus Silver...
TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Feb 23, 2009 | Texas Instruments TI-84 Plus Calculator
TI 84 Won't basically wont istall correctly
maybe because you don't have the ti connect installed.
Sep 01, 2008 | Texas Instruments TI-84 Plus Calculator
Ti-84 will not turn on
Did you try to adjust the screen contrast?
Dec 10, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
64 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
