Question about Weiser Lock POWERBOLT ELEC DEADBOLT
The old code continues to work even when I program in a new code. How do I keep that from happening?
Posted by chridandgayl on
Anonymous
    New Friend:
  • 28 Answers
Have you changed the batteries recently? If you have and the problem still exists, there is a reset code in the manual. Also, keep in mind that these locks hold two separate codes in them, when changing codes, make sure you change both of them. You acn find a copy of the manual here: http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Posted on Mar 05, 2011
My remote key fob stopped working after i dropped it in water. The door locks don't open with the key , they seem to be jammed. The passenger side door unlocked a few times with the key after jiggling it a...
It might work if you disconnect your battery for 10 minutes to clear the old Code and then reconnect it before you try to program the new FOB.
Oct 18, 2013 | 2000 Ford Taurus
I've searched far and wide, starting with RCA too no avail. Just don't see a model number or any program instructions. Again, it's a very old remote.
Wow ,, without the model number for that it will be very hard to give you step by step instructions or even tell if its compatible. but dont fear there is a possible solution. Notice that code search button the the remote ?? well basically some TV's share the same code so even if it inst listed doesn't mean it wont work.. Unfortunately you will need manual to tell you the exact procedure, but it should be something along the following..
1.) turn the tv on
2.) press and hold code search for 2 seconds or more until the LED lights continuously,
3.) press the tv button the led should blink and go out or bink and come back on.
4.) press the power button, if the tv turns off press the enter button to store the code.
5.) if nothing happens repeat steps 4 and 5.
Dec 27, 2012 | Televison & Video
For some reason I'm not able to open my emails in my yahoo account. I even tried to change my password but it's taking too much time in uploading page in weird manner. I see the status bar keep...
Try setting up a new account with a different ID. Then later you can continue working with Yahoo to fix the old one....or just delete the old one.
Jul 25, 2011 | Yahoo Mail
Ink indicator keeps on blinking even with new ink cartridge.
The blinking ink light means that the printer does not recognize one of the ink cartridges. Power the printer off, pull out the power cord, wait for awhile, replug and turn the printer on. If the light no longer blinks, ok. If not, try installing another cartridge pair if you have them available - even if they are old used ones. If the ink light continues to blink with different cartridges or if you don't have any different cartridges, old or new, you have a dilemma. Do you want a new printer or do you want to continue to chase this problem. To chase this problem, get new cartridges and install them (half the price of a new printer). If that works your set, but if not you need to have your printer serviced which is doubtful that it is worthwhile doing so.
Mar 03, 2011 | HP DeskJet 810c InkJet Printer
I keep putting new batteries in my camera and it doesn't work!
buy better batteries cheap batteries will not work in these cameras.
Mar 22, 2010 | Kodak EasyShare C643 Digital Camera
Deprogram an old code...
To do this you must hold the smart/learn button in for 6 seconds. This will erase the memory of the receiver and you will have to program your remotes plus the keypad.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cannot program additional remotes to new door opener
THe old transmitters have a differnt code...more than likely your new one is a riolling code and the old ones are not. They are not interchangeable.
Oct 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
My sony ericsson w890
Hi, the external and internal display has gone... is all black.. but the phone continues to work. I´ve shut it down and turn it up... but continues the same way. This cell is only 3 weeks old.
Can some one suggest a solution?
May 09, 2008 | Cell Phones
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
352 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
