It may be bad sector on HD or bad firmware update... first thing I would do is try to rollback firmware or reupdate firmware... Then take a look at the HD.... you may also try resetting it back to start on settings menu however you will lose everything saved.
Other than that you may want to look into replacing the HDD in the PS3.
or if you are using a USB
insert your usb drive:
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format:
hope this helps
