Purchased Philips Kitchen CD Radio AJ6111/37. Serial No. Aq100818075667. No template enclosed. Can one be e-mailed? [email protected]
Posted by karenray1964 on
kingnite
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 157 Answers
You can get the manual pdf from here: http://www.p4c.philips.com/files/a/aj6111_37/aj6111_37_dfu_aen.pdf
I'm not sure what you mean by template, other then this. If you need anything further, I'd suggest you contact philips at 888-744-5477.
Posted on Mar 05, 2011
I need Advice on how to get a Template for a Sony Kitchen Radio
Request the template from Sony. Be sure to specify model.
Aug 01, 2018 | Sony Audio Players & Recorders
Tip
How to upgrade the under cabinet lighting in your kitchen.
Hello. Here is a great weekend project that anyone can succeed with. Under cabinet lighting is such an enhancement to the function and cheerfulness of your kitchen. My most recent experience with this was very successful. The kitchen really needed the extra light and, the home owner let me choose the fixtures. I selected Utilitech line Voltage Xenon Lights from Lowes. These units come in three lengths, 12", 18" and 24". They can operate alone or in groups, they use 110 volts and no transformers, and they have a high/lo/off dimmer switch built in. Finally, they can be installed using the enclosed plug-in cords, or direct wired, and you can link up to 600 watts. A twelve inch bar is 40 watts.
All of that said, all you need to proceed is about 45 minutes per cabinet, and the following tools: electric drill and a set of wood flat drill bits, flat head screwdriver, philips screwdriver, wire cutters, wire strippers, pliers, safety glasses and a small mirror. The mirror will assist you in tightening the screws as you install the fixtures under the cabinets. Turn off the power at the breaker for the circuit you are working on [unless of course you are going to use the plug in cords included in the box instead of direct wiring].
VERY USEFUL TIP: probably the most difficult part of this task could be mounting each of the light bars uniformly under the cabinets. Recognizing this, I made a template for each of the three lengths of fixture so that I knew exactly where to predrill and start the two mounting screws required per fixture. These templates were made from still cardboard, cut with a razor blade knife, although you could have used 1/4 inch plywood just as well.
on Dec 07, 2009 | Electrical Supplies
Can someone help me find my radio code?
Does this help?
http://www.radio-code.co.uk/philips-radio-codes.html
Apr 22, 2014 | Office Equipment & Supplies
Ford 6000 cd visteon kw2000 6s61-18c815-ah V050350 keycode?
FORD 6000 CD SINGLE CD-KW2000 FDB2006 6S61-18C815-AH
Serial N V047160 . Name Dido
Feb 09, 2013 | Visteon Car Audio & Video
I need acronis true image 11 home serial no
If you are installing a trial version of Acronis True Image Home 2011 or Acronis Disk Director 11 Home, you do not need a serial number.
If you have an OEM version of an Acronis product (e.g. preinstalled on your hard disk, notebook etc), please contact your OEM vendor for a serial key.
If you purchased your Acronis product online, then you should have received your serial number in an automatic E-mail that was sent to the E-mail address that you provided at the time of the purchase.
If you purchased your Acronis product offline at a retail store, then the location of the serial number depends on the package:
  • Boxed product, that consists of the CD, White CD Sleeve, Quick Start Guide. - The serial number sticker is affixed to the back of White CD Sleeve;
  • DVD Amaray Case, that consists of the CD and Quick Start Guide. - The serial number sticker is affixed inside the DVD case on right hand side. Directly above where the CD is held in place.
If you still cannot find your serial number, you can try contacting Acronis Customer Central here: http://www.acronis.com/support/index.html?ow=1
Apr 09, 2011 | Acronis True Image 11 Home: Windows
I need code for my Radio Philips for my car. Please I need Code c
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
There should be a 14 character Serial Number (often found stamped in the metal casing ) and maybe a Security Number in the format of TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING you can find
Mar 20, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Serial NO lost
the serial number for this product is on the bottom of the box that the card came in, also look on the card
15 digit # that starts with12970
Aug 03, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Computers & Internet Logo
144 people viewed this question
Ekse
Muntejaya Ginting
Muntejaya Ginting
