Question about eMachines W3507 PC Desktop
I knocked the power switch,power LED &the hdd LED off on my Emachine W3507.Now I don't know where to plug these back in.What pins do they go in
Posted by Conquesta Turner on
  • Conquesta Turner Mar 05, 2011
    But my pins are not colored
MJ'S Computers .Unlt
    Habit-Forming:
  • 85 Answers
The cable connectors are the same color as the pins were they go.
Posted on Mar 05, 2011
    the pins on my motherboard are not colored.
  • lildonnie201
    lildonnie201 Feb 13, 2013
    im having the same problem
Looking for the front panel wiring diagram for a emachine T4510. The Power LED & the Power SW are disconnected! HDD LED was never unplugged! I need to know where they need to be!
If you look closely at the board there should be labels printed. The power switch plug can plug in either direction, but the LED must be the correct direction for it to work. No damage can be done by plugging the LED in backwards.
Jan 30, 2011 | E-Machines eMachines Desktop PC
HDD led flashes non-stop after case swap (emachine et1331g-03w)
it will be next to ur power led or u will find hdd led wrritten on the motherboard
Jun 04, 2010 | E-Machines eMachines Desktop PC
I have an emachine W3080 that I unplugged the front panel wiring, power switch, power LED, and floppy LED and dont remember which pins they plug into. Can you help?
their should be some abrevations like pwr led, pwr sw, hdd led by some metal pins in one of the corner of the motherboard
Feb 26, 2010 | Computers & Internet
I have a T2482 pc, I am not sure which pins the
See if you can find the motherboard manufacturer and circuit board #. Do a search either for manufacturer or motherboard number. They should have the pinouts. They might have a diagram of what color wire plugs where.
Nov 03, 2009 | E-Machines T2482 PC Desktop
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
I have emachine w3400 not powering . plz help
I found this right on this website, hope it works!
As for the fans, make sure your connections are tight and in the proper sockets.
Jul 09, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
May 13, 2009 | E-Machines eMachines Desktop PC
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Mar 05, 2009 | E-Machines eMachines T3830 PC Desktop
Emachine front panel power switch
Here's the Support Link for your desktop. Look under User Guides, Hardware Reference. Also look on the motherboard for markings such as PW or PS and an indicator to where the wire goes.
Nov 23, 2008 | E-Machines T3958 (827103050974) PC Desktop
eMachines W3507  PC Desktop Logo
317 people viewed this question
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
