You need to change the drum, which is a separate part than the toner. see http://www.nextag.com/brother-5250-drum/stores-html
Lights don't bleep.
If your drum light is on, but your print quality is good, just ignore it. It's just a reminder that the life of the drum has expired. If (when) you start having print quality issues, then you might want to replace the drum.
SOURCE: HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
I just had the same problem and fixed it. Hold down the blue "go" and red "job cancel" buttons at the same time for a few seconds. The printer churns into action and the green status light goes on. I was able then to print.
SOURCE: Toner life end.
-open front cover
-press 'Option' button
-then key *00 on the keypad
-This resets the device so it knows it has had a new cartridge.
I hope it helps
