SOURCE: fax centre F110
Reset 02 means the fuser is not warming up.
Most likely a fuser failure of the overheat thermostadt.
Need to have the fuser replaced most likely.
SOURCE: Printing issue
You need to replace the fuser. What is occuring is the teflon coating on the heat roller is worn and picking up some of the image off of the page and repeating it in a ghose like fashion.
Not a difficult replacement.
SOURCE: Xerox Phaser 8560 mfp Printing issue
That really sounds like you need to replace the maintenance kit.
The white roller most likely is black and has depleted itself of lubricant a bit prematurely.
SOURCE: received documents are going into memory almost immediately
Do you have a DSL or any other type of Digital phone line?
SOURCE: hi how do I turn
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
Hmmm, salty taste not bad (not from the pork loin, I know) and no police reporting of such an attack! That's OK, seems like you liked the abuse. Just wish you to at least be able to contact the dear gentleman and arrange a "repeat" or two!
P.S. Thanks again for all that usefull info shared with the public. OVER
