Question about Santa Fe 4027450 Dehumidifier
You should check if the compressor is running. Your description makes it appear that the fan may be running and the compressor may not be running.
There are many things that can cause a compressor to cease running:
Open defrost thermostat
Bad run capacitor
Low refrigerant charge (caused by refrigerant leak)
Bad compressor relay
Bad compressor overload
Bad compressor motor
Other things to check:
If the fan switch is set to "on" and the humidity control is set to a high humidity level, the unit may appear to be running, but the compressor will not operate. Check the setting of your humidity control.
If the dehumidifier is operating in a room with a high temperature and a low dew point (very low relative humidity), it may be unable to remove any more moisture from the air.
If you are not comfortable troubleshooting the unit on your own, call the manufacturer service department at 1-800-533-7533, EXT 8459. They are very helpful.
Posted on Mar 07, 2011
Jul 23, 2015 | Dehumidifiers
Sep 10, 2014 | Santa Fe Compact Dehumidifier
Jun 02, 2014 | Whirlpool 75-Pint Dehumidifier
Jul 03, 2011 | Dehumidifiers
Jan 11, 2011 | Santa Fe Advance Pre-Filter Dehumidifier
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Aug 01, 2009 | Dehumidifiers
Jul 06, 2009 | Dehumidifiers
Jul 01, 2009 | Kenmore 54501 Dehumidifier
Jul 02, 2008 | GE AHG40LJ Dehumidifier
1,033 people viewed this question
