Hi
If your coffeemaker appears to be clogged. Create a vinegar and water solution and flush the concoction through your coffeemaker pump. This will help dissolve build up in your coffeemaker. If you do this once a month, your coffeemaker pump won't clog.Unplug the coffeemaker and inspect the pump valve. Water won't rise through the fill tube if the pump valve is stuck or broken. If your pump is sealed, replace the pump. If the pump valve is accessible, make sure there are no coffee grounds or mineral deposits around it.
Also check the brewing switch is in good working order. Remove the base plate on your coffeemaker and test the switch with a volt-ohm meter. Set your volt-ohm meter on the RX1 scale. If your switch reads zero ohms, your switch works fine. If it reads anything other than zero, replace the switch. Also take a look at the tube connectors, if your coffeemaker is sputtering, leaking or steaming. Leaks in pump coffeemakers are often due to faulty tube connectors. Unplug the coffeemaker and fill the reservoir with water. If water leaks from an elbow, clean the mating surfaces before replacing it. If your water leaks from a tube connector, replace the tube and mating elbow to ensure a good fit.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
