Hi
Remove the trim from around the dispenser area then remove the catches in the top of the electronic board. Lean the electronic board forward and disconnect the electrical connections, then remove the electronic board. Then remove the four screws holding the shield to the door and removed the shield. Remove the funnel from the shield and remove the spring from the old funnel and place it on the new one. Now remove the light and socket from the old shield and installed in the new one, then install the new funnel on the new shield, used the four screws to install the assembly on the door and replace the trim piece. Hope this helps... Please post back if you need more information.
Daniel
Posted on Mar 06, 2011
Carefully removed the trim from around the dispenser area by gently prying the trim off careful not to brake it. then freed the catches in the top of the electronic card. I leaned the card forward and disconnected the electrical connections, then removed the card. I removed the four screws holding the shield to the door and removed the shield. Then I removed the funnel from the shield and removed the spring from the old funnel and placed it on the new one. I removed the light and socket from the old shield and installed the in the new one, then installed the new funnel on the new shield, used the four screws to install the assembly on the door and replaced the trim piece. Here's a DIAGRAM to help.
Posted on Mar 05, 2011
cannot pull outer trim off because the aliminum door facing is in the way
keith
did not recieve a reply from my last question re surround
Hi the trim will not come off because the stainless steel outer door covering prevents it from being removed
