Samsung Digimax S600 Digital Camera Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i unlock the sd card in my s600? - Samsung Digimax S600 Digital Camera
Anonymous
Level 3:
  • Samsung Master 6,771 Answers
  • Posted on Mar 05, 2011
Anonymous
Samsung Master
Level 3:
Answers
6771
Questions
0
Helped
1778969
Points
21413
Remove the memory card from the camera, look along the one edge for a tiny switch, slide it towards the contacts to unlock the card, the switch farthest from the contacts is in the locked position to prevent deletion. Now! if the card is in the unlocked position slide it back forth to reset the card, if it fails the card should be replaced.
Anonymous
Level 2:
  • Expert 300 Answers
Anonymous
Expert
Level 2:
Answers
300
Questions
0
Helped
101426
Points
783
Take a look at the SD card. On the left side of it, there's a small plastic switch. Make sure it's switched to the upper position. If that doesn't help, the mechanical switch inside the camera that detects if the SD card is locked, is broken. It has to be taken apart to repair it - you will have to give it to a technician.
Tom
Anonymous
Level 2:
Sergeant:
  • Expert 167 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
167
Questions
0
Helped
29242
Points
582
Remove the card from the camera. The is a little switch on the left side. Slide it up. Put the card back in. Should be unlocked.
1 Related Answer
willem52
Willem.
  • 359 Answers
  • Posted on Jun 09, 2011
SOURCE: i have a samsung digmax s600 i works fine without
Be sure you have a standard SD card to put into this camera, not a SDHC type.
You will be limited to a maximum of 2GB with SD, but it should work perfectly.
If not, check the SD card in a notebook or PC's cardreader and/or replace the
SD card with another one. If this does not work the SD card interface in the
camera may be defective.
2helpful
Memory card
You may use any MMC or SD card, 2GB or smaller. MMC cards are nearly extinct to an SD card will be easier to find. You don't have to worry about the brand or speed, though personally I'd go with the major brands.
Make sure you get an SD card, 2GB or smaller. The S600 will not work with higher-capacity SDHC cards.
What is card is locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
I have a samsung digmax s600 i works fine without the sd card inserted but when i insert the sd card the camara wont turn on
How do I unlock the memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
The card is locked
1helpful
Card is locked
SD cards have a slide switch along one edge. Slide it fully away from the contacts, then fully toward them. The position nearest the contacts is the unlocked setting.
2helpful
2answers
Hi,just bought a 4gb sd card for my digimax s600 but it won,t work.when i switch on camera, screen says..format..yes.confirm ok.when i do this i get check sd card . i put in old card it works fine??..
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
SD card not working on EX-Z1 Exilim cammera?
Are you sure you have an SD card, 2GB or smaller? The S600 will not work with the higher-capacity SDHC cards.
The camera wont work with a 4gb sd-card............why?
The S600 is designed to work with MMC and SD cards, which top out at 2GB. It is not designed to work with the newer high-capacity SDHC cards.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
