If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
