> Steps To Check the Password For your wireless Network on Dynex Router ( By Default the Security Mode is Disabled )
- Connect your Computer to the router Using an Ethernet cable
- Launch a Web browser (Internet Explorer, Firefox, Safari or Netscape), Enter 192.168.2.1 in the address bar of the browser and hit "Enter". Click on "Login" while leaving the password
field blank.
- Towards your Left corner under Wireless Click on Security
If Security Mode is: WPA
Down Below in the Password (PSK) Box you will Find your Password
If Security Mode is: WEP
The 10 Numbers in Key 1 box is your Password
Copy this link and past it into your Browser>>Hit Enter>>If you are using IE then it start to download PDF file>>once it complete the download>>>now you can follow the instruction to see your security key or even you can create a new security key for your wireless router.
It shows 2 ways to set up your secure wireless connection
One by disk if you have one for your wireless router step by step.
Another method manually by going into router console page by 192.168.2.1.
Use any of the method which is convenient for you.
http://www.google.co.in/url?sa=t&source=web&cd=7&ved=0CFcQFjAG&url=http%3A%2F%2Fen-us-support.belkin.com%2Fapp%2Fanswers%2Fdetail%2Fa_id%2F3669&rct=j&q=security%20key%20for%20my%20dynex%20dx-wegrtr%20router%20setup&ei=CUFyTdSgD4rkrAeHjd3RCg&usg=AFQjCNFfTvxh36mJ8P0XqHt1Uq2ZrI_yMA&sig2=uT59GHEkdO_2dTFDcvUKKA&cad=rja
Best of luck.
cheers.
Log into the routers interface usually 192.168.1.1 or check the default gateway address with the ipconfig command in the command prompt. Then navigate to the wireless security tab and the key should be listed.
