Question about Mitsubishi Wireless USB Adapter (AWNU231) Pre80211n
Wireless dongle won't connect to verizon wireless network. Wireless Password is entered into TV Internet connect screen and returns a message "Error Unable to Connect". Device is not listed in route ip addresses.
Posted by paininthe400 on
Matthew Huffman
  • 53 Answers
Make sure everything is compatible for the type of wireless network you are using g/b/n and you are using the correct radio frequency. Also make sure you are using the correct wifi dongle for the make of your TV. From what I recall I do remember some of them being proprietary because the TV will have to have pre-loaded drivers for the wireless dongle.
Posted on Mar 05, 2011
How do I connect my Roku to the Home Network?
Hi friend...
Connecting to your home network and the internet during setup, During Guided Setup, you will be asked to do the following:
1. Choose Wired or Wireless.
Note: The Wired option will not appear on Roku devices without an Ethernet port.
2. If you select Wired, your Roku device will connect to your home network and the internet. If you select Wireless, proceed to the next step.
3. Choose your wireless network from the list of available networks. If you do not see your home network, select scan again to see all networks.
4. Enter the password you use to access your wireless network. If you want to see the password as you type, choose Show password. This can help prevent entering the wrong password.
5. Remember, passwords are case-sensitive. Use the shift button shift key on the on-screen keyboard to enter a capital letter.
6. Once you have entered your password and selected Connect, your Roku streaming device will connect to your home network and the internet.
7. After your Roku device makes a successful connection, the latest available software for the device will be downloaded and installed, and your Roku device will restart.
If you cannot make a connection, learn what to do if your Roku device cannot access your home network or the internet.
For any help visit us: www Roku Com Support
Jun 15, 2018 | Roku Streaming Stick
How do i connect my luxor tv to the internet wireless
As far as I know there is only one Luxor TV model that has Internet access (Smart TV) and it comes with a wireless adapter/dongle. Plug the dongle in the USB port of the TV set and follow the instructions in the user guide on how to set up a network connection. Usually, from your remote, go to Menu, Settings and then to Set Up Network Connection. Please be aware that you need to have a wireless modem/router for your home network in order to be able to connect your TV to the internet.
Hope this helps.
Nov 19, 2014 | Computers & Internet
How can I enter password in roku 3 I don't know how it connect and not work
I have created this document that will step you through the setup and also enter your password for your network. Hope this helps you.
Follow these steps to setup your Roku player 1. Connect to your TV
  • Use a HDMI cable. Connect one end to the HDMI port of the Roku player, and the other end to an available HDMI input on your TV.
  • Make note of the TV input used.
2. Power up key components
  • Open the battery compartment and carefully insert the provided batteries into the slots, following the correct battery orientation.
  • Power up the Roku player by connecting the provided power adapter to the Roku player and to an available wall outlet.
  • Turn on your TV and select the correct TV input.
3. Connect to your network
  • If you are using a wireless network, select "Wireless" as your network connection:
  • Select your network from the list of available networks.
  • Enter your wireless network password when prompted. (Note: passwords are case-sensitive)
  • If you are using an Ethernet wired connection, select "Wired (Ethernet)" as your network connection.
4. Complete guided setup
  • Get the latest software
  • Your Roku player will let you know if there is a software update available, and will restart after the update
    is complete.
  • Link your Roku player from any Internet browser
  • A link code should be displayed on the TV screen after restart
  • Using an Internet browser, follow the instructions to link your Roku player to a new or an existing Roku account.
Help for common setup mistakes and solutions
Symptom
Possible causes
Try these!
I don't see any picture on the TV
TV is OFF
Cable loose
Roku is OFF
Wrong TV input
Ensure TV is ON (it's more common than you think)
Check all connectors are snugly in place
Check power adapter is snugly connected, and wall outlet is working
Select the correct TV input
I can not connect to wireless network
Weak wireless signal
Wrong wireless name
Wrong wireless password Wireless name hidden
Move Roku player location (even a few inches may help)
Ensure correct network name selected
Ensure correct password entered
SSID can be hidden, use "Add Network" from wireless network screen
My remote does not work
Not in line of site
Batteries weak
Get closer and ensure there are no obstacles between your remote and the Roku player
Try a fresh set of batteries
Resolving wireless connectivity
If your Roku player isn't connecting to your wireless network, try the following:
Description
Do this
Tips
Repeat guided setup • •
Go to Settings>Network>Wireless•
If "Update connection" is available, select it to refresh your connection
If not, just select your wireless network from the list, enter your wireless password when prompted
If you were previously and just lost connection, you may not need to enter your password again
Passwords are case-sensitive
Restart the Roku player and • your wireless network
Unplug the power connector from • the back of the Roku player
Unplug the power connector from the back of your wireless router
Unplug the power connector from the back of your modem
Plug the power connector back into modem (wait a couple of minutes for it to fully boot)
Plug the power connector back into the wireless router (wait a couple of minutes for it to fully boot)
Plug the power connector back into your Roku player, and wait for the image on your TV
Follow repeat guided instructions above
Your wireless router and modem may be combined as one device
Factory reset the Roku player
From the Roku home screen, sele•ct Settings>Factory reset and follow the instructions
Note: You can also reset the Roku• player using the reset button. Find the reset button on your Roku player, press and hold for 15-20 seconds ( the front LED will rapidly blink a few times)
Factory reset should be used as the last resort, if all other steps failed to recover functionality
After a reset, you will need to relink your Roku player to your Roku account, and setup subscribed channels with username and password, if applicable
If you forgot your password, you can recover it here at this URL:
Forgot Password
A new password will be sent to the email account listed in your account. If you do not see the email, be sure to check your spam filter.
Sep 12, 2014 | Computers & Internet
Where do i find my ssid
It will be written on a label somewhere on your wireless router/access point, which is in most cases the box provided to you by your internet provider to let you access the internet.
You'll most likely be prompted for a password as well, this is also found on the same sticker.
Aug 26, 2014 | Netflix
How can i connect sky through my lg dongle. what passwords do i need to enter. thanks
The password for your sky wireless will be written on a label on the sky router itself - use that
Jul 13, 2014 | LG ANWF100 Wireless dongle
Need to connect my tv to the internet
Wifi dongle will available for TVs. If you had USB port on TV,connect that dongle on that and access internet.
Nov 10, 2013 | Sharp LC46SB54U 46 in. LCD TV
Lg dongle won't connect need help I have all lg electrical equipt
some dongles are made by only to connect to the desktop or the laptops only. better thing is ask the service provider who sold that dongle.
Sep 02, 2012 | LG ANWF100 Wireless dongle
I have a samsung LCD TV Model LA40C650L1R newly purchased a week ago . it went with an offer of free wifi wireless LAN adapter.I cant seem to connect it in the internet. I did all the configurations the...
Please test the WiFi with a laptop or netbook, if Internet works with it, maybe you have bad settings into the wireless adapter, you could use the PC wireless connection parameters (SSID, IP address, subnet mask, gateway, DNS) as reference with the data obtained with the TV wireless adapter, the only difference must be the IP address, the rest must be the same since they're using the same network.
Mar 15, 2011 | Samsung Televison & Video
We have KDL-55EX711 Bravia and want to connect to the Internet. Shaw has given us a wireless modem but we can't connect. Help please!
I too just bought the KDL-55EX711 Sony Bravia and have connected it to the internet. This TV is awesome! To connect to the internet, however, you still need a wireless access point or wireless router to have that the TV can communicate with.
The TV comes with a wireless USB ethernet card "dongle" that you must plug into the USB slot on the side. After connecting the USB wireless card to the TV, connecting to the internet is just like connecting a laptop to a wireless network. You must go to the network settings menu on the TV follow the instructions there to get connected. In a nutshell, the TV will list the available networks to connect to. Find yours and try to connect to it. If your network is secured, you might need to enter a password that you have already set up for your wireless network. Finally you can either enter have the TV ask for an IP address and other settings or enter them yourself. You should not try to enter the IP address and other values yourself unless you know what you are doing.
Feb 19, 2011 | Sony Televison & Video
Mitsubishi Wireless USB Adapter (AWNU231) Pre80211n Logo
344 people viewed this question
Top Mitsubishi Computers & Internet Experts
Shaukat Bhutto
Shaukat Bhutto
Marvin
Marvin
gary433
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
