Aurora Electronics AS1018CD Shredder Logo
Question about Aurora Electronics AS1018CD Shredder
Does not activate when paper inserted. Runs ok in reverse indicator lights are ok
Posted by mappintltd on
Anonymous
    New Friend:
  • 42 Answers
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. Don't open your shredder to repair it yourself because it will void your warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Posted on Jul 25, 2011
My royal sp12mx will work in reverse but nothing happens when i insert paper to shred. light is on
there is a very small lever between two cutters around the middle that activates a microswitch to turn it on when you offer paper to be cut
the problem will be in that area ( switch or lever broken) as it's purpose is to switch on the cutters
reverse is straight drive from the control switch
Runs in reverse when paper inserted motor runs but paper does not move
there is a reverse switch for paper jams, someone has moved it, flick it back
3helpful
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
4helpful
Runs only in reverse
Switcheson fine but does not accept paper
Does it run in reverse???? Does the motor work.???
If it runs in reverse then the motor is probaly OK....does your machine have "eyes" that automatically start the shredder when the paper is inserted??? if it does then they may be "dirty/dusty"...try cleaning them ; if that dosn't fix it then you may have defective "eyes" or defective pcb.
The engine runs when paper is inserted but the mechanism does not grab the paper, also it whines loudly when switched to reverse???
the rubber who grab the paper is used, need to be replaced, and check for all input rubber situation, probably needs also to be replaced
2answers
Runs in reverse, but no on auto.
check and see if there is a jam of paper inside the unit or around the sensors
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Top Aurora Electronics Office Equipment & Supplies Experts
Marvin
Marvin
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
