Question about Skype IM
Skype dont wont to install on windows xp fatal error d3d9.dll.when i restart my comp.i have some message like fatall error and 3d9d.dll and something else
Anonymous
  • 9 Answers
Try first installing Microsoft Directx9c from the Microsoft site directly, link below:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displayLang=en
This should place the necessary missing files Skype requires.
Posted on Mar 05, 2011
Anonymous
    New Friend:
Many of the d3d9.dll errors occur when you have older version of DirectX on your PC. For instance, you may receive d3d9.dll errors, similar to the ones listed below in case you try to run a game or a program that is specifically written for DirectX 9 on a PC that uses DirectX 8 or some other older version. Download the latest version on the DirectX Homepage: http://msdn.microsoft.com/en-us/directx/aa937788.aspx or search the Update: http://windowsupdate.microsoft.com/
Anonymous
  • 157 Answers
1) Use can use the Skype via website: http://imo.im
2) Download the Skype again (full version): http://www.skype.com/go/getskype-full
2) Try to install any other program - if you experience similar problems with missing files then maybe one of your RAM (operative memory) modules is damaged. If you have 2 RAM modules try to pull one of them out and check how computer operates and installs software, if something is still wrong, check the second RAM module alone. If you have only 1 RAM module, re-plug it to another RAM slot (maybe the slot is damaged).
  • Anonymous Mar 07, 2011
    P.S. If this helped you to solve the problem (or at least brought some clarification) - rate this solution with 4 thumbs up! But before you would give a negative rating - post a comment, so I could improve my solution to satisfy your needs. Thank you!
I install skype for video calling &i done it also update is completed but a arises that when i click on skype to start a message is arise that fatal error :d3d9.dllperf_set option(d3d9.dll).plz send me...
YOU SHOULD MAKE SURE THAT NEW RELEASE LEVEL IS NOT SUPPORTED ON WINDOWS
XP
I just bought a HP webcam, downloaded this latest version of SKYPE and could not get it to work. Last night I spent over 2 hours with HP support. The problem resolution was that Skype 5.0 does not work with XP. HP support installed SKYPE V4.2.0.169 and got it working. Your download web page still says download new version...
thank you
Aug 02, 2011 | Computers & Internet
Fatal error D3DPERF_SetOptions(d3d9.dll) comes when I start skype.Please tell me how to solve this error.
Hi !
Just uninstall and reinstall again the skype software because the skype driver file is corrupted that make an error.
I hope it helps you.
Feb 01, 2011 | Skype IM
When skype install during fatal error failed to get proc address for D3DPERF_setoptions (d3d9.dil)
Try updating your DirectX from the Microsoft site.
OR
Find 'd3d9.dll' file in GOOGLE, downloaded it and put into ..windows/system32 (replace existing), restart PC and now the problem is solved.
Jan 05, 2011 | Skype IM
Fatal error : failed to get proc D3DPERF_setOptions(d3d9.dll) when downloading skype
Do a Google Search for D3D9.dll, then place the DLL File into your Windows/System32. Replace the existing file if needed. Restart the PC and it should be solved.
Jan 01, 2011 | Computers & Internet
Whenever we try to open skype a dialoge box apppears showing fatal error failed to load library d3d9.dll.
You will have to re-install the Skype application in order to get rid off the error.
Please follow the below step:
1. download and install the Revo uninstaller application online(It's free).
2. Look for the "Skype" application and select the "uninstall" option.
3. Select "Advance" scan and remove all the remaining files of skype.
4. Reboot the computer.
5. download the d3d9.dll file from the following website http://www.dll-files.com/pop.php?dll=d3d9
6. Copy the d3d9.dll file and paste it at the following location C:\windows\system32
7. You will have to register the dll file before installing the skype application. To register the dll file:
Click on "Start" menu and select the "Run" option or Simply Windows key+R
Then, type regsvr32 d3d9.dll and click 'OK" .
8. Once the dll file is registered, you can install the Skype application and continue using it.
I hope this should fix the issue.
Thanks, Vicky
Dec 27, 2010 | Compaq Presario 5000 PC Desktop
Cant install showing fatal error 'failed to get proc address for D3DPERF_SetOptions (d3d9.dll)
You will need to install Microsoft Direct X before you install Skype. You can get it from http://www.microsoft.com
Dec 25, 2010 | Skype IM
How to rectify fatal error d3d9 dll in skype
hey there
well fatal error is ram error check your ram maybe it'll work!
Dec 21, 2010 | Computers & Internet
I installed skype version 5.0. and after i tried to start it up on my screen appeared fatal error for d3d9.dll
you might have to download and install later/better copy of DirectX
hope this helps
Dec 05, 2010 | Computers & Internet
Skype IM Logo
1,271 people viewed this question
Top SKYPE Computers & Internet Experts
Mike
k24674
Rob Hill
Rob Hill
Are you a SKYPE Computer and Internet Expert? Answer questions, earn points and help others
