Question about Technics SL-1210 Turntable
I am looking for new covers for my 1210 mk2 turntables
Posted by djstarmike on
Styluscity
    Champion:
  • Technics Expert
  • 271 Answers
Hi, we have them in stock. [email protected]
Posted on Mar 05, 2011
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
How do i change the speed of technics 1210 mk2 back to the original speed?
if you take off the platter, then undo the plastic board covering and protecting the circuit board...then once you have access to the circuit board...there should be a little blue knob, usually located top right...its basically a matter of turning it untill you are happy with it, unless you have a little mark on the blue knob and the circuit board...if you or someone has done that, then that will be the master setting, of +8/-8 pitch
Jul 21, 2009 | Technics SL-1210 Turntable
1210 mk2 speeds up on its own
hi ,,,the pitch control is good dont chance it ..you have a problem on the main board ...of your turntable...check the cold solder of your main board of your deck....maybe some of them are loose that why you got a wiggle platter.. u...then fidbk me wat happend? u
Jun 18, 2009 | Technics SL-1210 Turntable
Turntables lags on pick up
I have the same exact problem with one of my 1210 MK2 turntables. It seems like the motor is too slow now. When I hit the start button or release the record, it takes much longer to speed up to the normal speed than my other same exact turntable. I don't think it has anything to do with the pitch slider. Please let me know if you find out what the problem is thanks!
Mar 18, 2009 | Panasonic Technics SL-1210MK2 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
1210 mk2 only playing through left speaker checked everything and needs new rca phono lead how easy is it to change thanks
If you have done some soldiering and have a steady hand, it's not difficult. If you are not sure, you could destroy that little circuit board that the lead runs to, and technics had discontinued production of that part. I'd say get it done by a pro with experience.
These guys are top notch:
http://www.repairnyc.com/
Hope this helps.
Jan 13, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
59 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
