Question about Jazz DV-171 Camcorder
I transferred movies files stored in SD card into a notebook, and deleted the entire movies from the card. subsequently, I copies these files back into SD card and inserted it into my Camcorder again (Canon Legria FS200), however, the camcorder could not detect the files at all. I have copied these movies file into a sub folder SD_VIDEO\PRG001, and I have also copied PRG001.PGI into it. What have gone wrong?
    New Friend:
  • 16 Answers
Are you sure the files are transferred to the sd card. With some camcordes you can transfer files back and forth, you can only copy the to your pc... unplug and plug it in again and check if the files are still there if aren't use a sd card reader to transfer these files back to your cam. But if the files are on the sd card and your camera still doesn't read them, try recording a new movie, see where it's located, does it have a seperate folder and try doing the same with your org movie. I hope it helps. :)
Posted on Mar 05, 2011
6ya staff
SOURCE:
How do i download the movie i have on my tablet to the sd card
Download and install a File Manager application from the App Store (for Apple tablets) or Play Store (for Android tablets). It is like the Windows Explorer on your Windows desktop/laptop. Open the application and search for your movie file. Then copy it and paste it into the SD card, the way you would copy a file from one directory to another with Windows Explorer.
Hope this helps.
Dec 14, 2014 | Tablets & eReaders
Please Help
hmmm you should try the followings:
First insert your SD card and try to make a copy of your pics from camera memory to your SD card. And then use this SD card to your computer.
Or Using Camera manufacturer and model no. search some driver and software for you so that you can transfer the pics to computer.
if still not fix, let me know your manufacturer and model no.
Thanks
iqbal
Mar 23, 2008 | Samsung Digimax S630 Digital Camera
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
My kingston sd 1 gb card from camera is reading as wehci when inserted on to my laptop and not showing photos stored in it
Another common problem that people have with digital cameras is that they have trouble transferring movies and photos to their laptops. To do this, all a person needs is a working computer and a USB cord. Some digital cameras come with these cords and others are found in most stores that sell electronics. Once you have this cord, it needs to be attached to both the computer and the digital camera. A folder will pop up once the computer recognizes the camera, and you can then copy files. Once the files are copies to the computer, they can then be deleted from the camera.
May 03, 2011 | Cameras
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
My gps device wont load.
if you mean you moved everything from the flash drive to the sd card, plug in your 3100 to your computer via the usb cord and also plug in the home charger if you have one, or make sure the battery is fully charged by plugging it in fo a few hours.
put your sd card in your card reader, open the sd card drive in your computer and copy (do not move them, use the copy option) then copy the files in to your flash drive for your 3100.
it will take awhile to transfer those files, because its like 1.6 gb.
after its done transferring the files, reboot the 3100. if that fails, let me know by replying to this post so i can continue to help you.
bill
Feb 10, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Data transfer
Basically you need an SD card.
Located in the "Save Data" section of the "Data Management" area of the Wii Settings Save Data are the files created when you save a game's progress (such as high scores, items found, and where the game last saved), as well as data for certain Wii Channels
This data is stored in this section separately from the Wii Channel data, and can be kept, copied, or deleted independently of the Wii Channel it is used for.
Copy the Save Data to an SD Card, then delete it from the Wii
Most Save Data, including Virtual Console or WiiWare save files, can be copied to a compatible SD Card. This gives you the ability to delete that data, then copy it back over from the SD Card to your Wii should you wish to get it back at a later time. (Be sure to copy the data back over to the Wii when you wish to use it again; simply having the SD Card inserted with the data on it will not allow it to be used.)
Jul 09, 2008 | Nintendo Wii Console
Transferring MP3 files from PC "C" drive "My Music" folder to SD card
you may want to try downloading only those that didn't download the first time. Sometimes when you try to download a large file (all the songs) it causes the "error message" you talk about. You may want to delete files already downloaded, or save the files downloaded to a different file folder, and try the download again.
Dec 27, 2007 | iLO (2 GB) MP3 Player
Deleted MP3 files still play on my Nuvi 660.
Go to the GARMIN M3U file , open it and do what you want .Transfer, delete , copy and so so....
Dec 23, 2007 | Garmin Nuvi 660 GPS Receiver
Jazz DV-171 Camcorder Logo
202 people viewed this question
Top Jazz Video Cameras Experts
jcb93
Level 1 Expert
Ekse
Marvin
Marvin
Are you a Jazz Video Camera Expert? Answer questions, earn points and help others
