Question about Toshiba CZ27T31 27" TV
It says u cant make a toshiba model # cz27t31 willnot work w/ unniversal remote , mines for cable w/ dvr. the problem i had is # not long enough. it just changes 2 that channel, cuz channels go up as far as remote# thanx, mary
Posted by bakaymary196 on
2 Related Answers
hhtfgg sdghr
  • 231 Answers
SOURCE: Cannot set my toshiba television to the input channel manually
if you go to channel 2 then channel down the channels between it and the highest are your input channels hope this helps
Posted on Apr 14, 2010
Ironfist109
Iron
  • 3018 Answers
SOURCE: I lost the remote to
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 20, 2011
My Toshiba CZ27T31 TV power light is on but I have no sound or picture. Why?
You probably have the wrong input selected on you TV. Turn everything on and find the "source" or "input" button on your remote and change inputs until you find your signal
Sep 03, 2014 | Televison & Video
I have a toshiba ct 90159 - I need the code for a coby dvr model dvd 627
u should be able to
turn the dvr on
press and hold the setup until the light stays on (remote)
hit the dvr botton on the remote the light should blind once
hold the remote towards the dvr keep hitting the on and off button on the remote until the dvr turns off can take up to 300 times once the dvr turns off press the select button and that should fixya up
Mar 31, 2012 | Toshiba CT-90159 Remote Control
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
How do I work my camcorder
What brand of DVD recorder? On my Panasonic, I use RCA cables to connect my camcorder to the yellow and white inputs on the front of the DVR. I have to press "input select" on the remote a few times until I get to L2, I think. This is a "line in" sort of setting and it directs the DVR to get its input from the RCA-style cables. Have your camcorder playing something you've recorded in its Video mode. If your TV is on the correct input (mine is called "Video 2", I think), you should see the camcorder image on your TV screen. Now, just rewind to the beginning of your camcorder tape. Insert a DVD-R disk (that's what mine takes) in your DVR. Hit Play on your camcorder and quickly press REC on the DVR remote. Let me know if this doesn't work.
Apr 03, 2009 | Canon ES400V Camcorder
Time warner code for Fujitsu 42" tv
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066
let me know if that works for ya
ric
another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
Nov 10, 2008 | Toshiba 36A50 36" TV
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Dec 26, 2007 | Universal Remote Control NspireGear MP3...
Audio, but No video when connecting DVD player to TV
Try checking the AV cable. Just interchange the Audio and Video cables, and if now you get video, and no audio, problem is faulty cables. Replace.
Apr 15, 2007 | Toshiba CZ27T31 27" TV
Toshiba CZ27T31 27" TV Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
