Question about HP DeskJet F4280 All In One Printer InkJet
My hp f4280 keep saying door open but there is no error light on.
Posted by adwright66 on
Anonymous
    New Friend:
Mybe dis is a problem with your sensor because it connot detect if the door is cloos or open mybe the sensor is dirty or damage
Posted on Mar 05, 2011
I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Dec 30, 2009 | HP Office Equipment & Supplies
Why doesn't the HP Deskjet F4280 scan documents to PDF
to get pdf files you have to have adobe installed in the computer
Jul 01, 2017 | HP DeskJet F4280 All In One Printer InkJet
Machine says out of color ink. when i open the front panel to see what number cartridge I need, the carrier hides in the right hand corner instead of coming to the center where I could remove it. I would...
Your cartridges are supposed to move all the way to the right. Please refer to this link for replacing the cartridges:
F4280 Cartridge Replacement
Your cartridges are HP 60 Black and HP 60 Tricolor. Here is a link for your supplies from HP:
HP F4280 Supplies
Thanks for using Fixya.
Oct 10, 2009 | HP DeskJet F4280 All In One Printer InkJet
F4280 not able to set the size of paper scan!#@$
1. All you need is Uninstall the the printer from your control panel.
2. go to my computer and open your Hard drive (C:)
3. Go to the programs folder and open it.
4. delete the HP F4280 folder.
5. reinstall the printer.
Make sure that your printed is not connected to your PC during software installation until you are being told to do so.
Aug 08, 2009 | HP DeskJet F4280 All In One Printer InkJet
My Hp printer keeps saying "resume".
Do a complete reset.
1- Clear the printer queue.
2- Turn off the device.
3- Remove paper in the tray and possible paper jammed.
4- Remove ink toner.
5- Turn on the device briefly and turn it off.
6- Replace paper and toner.
7- Turn on!
Mar 27, 2009 | HP DeskJet F4280 All In One Printer InkJet
How do you remove ink cartridge of HP F4280
The cartridge door is to the right of the paper tray. It is hinged like a regular door...open it to the right.
The cartridge carrier should move to the right to access them.
To remove the old ones, press down slightly on the rear of the cartridge and tilt it out. To insert the new one, angle it upward slightly at first then apply pressure down in the front and up on the rear until it clicks into place.
Here is a link to the Setup Guide if it would help.
F4280 Setup Guide
Dec 11, 2008 | HP LaserJet 1018 Printer
HP DeskJet F4280 All In One Printer InkJet Logo
244 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
