hw can we apply "flashing the phone ?" i am facing the same problem and i am unable to clear the last call time history in nokia 1200 plz help me hw can i delete the last call timehw can we apply "flashing the phone ?"
You can't post conmments that contain an email address.
The clearing call timers should be in the following scren. 1)Go to menu 2)Select call register 3)Select call duration And clear it all the info will be lost you might be asked for a password. If you have never set a password the default one is 12345
Sounds more like it's been set to do that. Use the following to shut off the timer mode. It's possible that the set is set to the wrong time of day but that is unlikely. You can shut off the timer mode using the on screen menu. Follow the instructions below.
Using the Timer Menu Current Time Set your TV to the current day and time. Press to open the Current Time menu: 1 Use the F or f buttons to enter the correct day and time, then press . 2 Press to exit the menu. Timer 1 and Timer 2 Scheduled viewing Use the timers to program your TV to turn on and off by day, time, duration, and channel. The timer duration is a maximum of six hours. When the channel is fixed, it is not necessary to set the channel. 1 Use the F or f buttons to highlight Timer 1 or Timer 2, then press . 2 Use the F or f buttons to enter the desired day, start time, duration, and channel, then press . The timer status should be On when the Timer has been set, and the timer light on the front panel of the TV should be on. 3 Press to exit the menu. ? When you perform Auto Program, Timer 1 and Timer 2 settings will be cleared. Also, in the event of any loss of power, Current Time, Timer 1, and Timer 2 settings will be cleared
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit 1. To Start - turn dial to Off and press Enter. 2. Set Time - set current time and press Enter (Yellow ring). 3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter. 4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter 5. Duration - Set duration of cycle (Green band) minutes and press Enter. ---------- To change duration - turn dial to new duration and press enter. To turn water on manually - Turn dial to ON position, water will turn off in 30 min. Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit via steps 2-5 above.
At the start screen, select Menu -> Call History -> Minibrowser calls and one of the following options: Last sent browser data:—View the size (KB) of the last sent browser data. Last received browser data:—View the size (KB) of the last received data. All sent browser data:—View the size (KB) of all sent browser data. All received browser data:—View the size (KB) of all received browser data. Last browser session:—View the duration time of the last browser session. All browser sessions:—View the duration time of all browser sessions. Clear all browser logs:—Select OK -> Yes to clear all browser logs.
for reset timer u dont have to format mobile
just go to call register in menu u see clear timer option select it mobile will ask for lock code
if u have update any phone lock insert it or just insert 12345 (default code) all timer will reset
Please clean the microphone on the phone. The small hole on the bottom end of the phone may be blocked. Also, the microphone contacts on the circuit board may be loose or dirty. Please have a technician open up the phone and clean/adjust these (you can also do this if you feel comfortable with it)
