You should have plenty of USB ports on your motherboard. or your case. If you don't have any open USB ports you can get a USB to PS2 adapter. Like this. http://sewelldirect.com/USB-to-PS2-Adapter.asp
Or you can buy an external battericharger like the BC-65. It's not cheap either but you only need one item. Instead of the USB cable you can use an external USB card reader that can take XD cards.
You need an AC adapter; you would plug the player's USB cable into the player, then the other end into the AC adapter, then plug the adapter into the wall to let your player charge.
Go to your local electronics store (Best Buy) etc. and tell them you need a USB AC adapter for your MP3 player. Bring your player and USB cable, just in case.
if you have problem with the PS/2 slot, then you can buy a usb to PS/2 adapter or you can buy a usb keyboard.
if you have problem with the usb slot, then you can buy a PS/2 to usb adapter or you can buy a PS/2 keyboard
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port. However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps. Rate this solution if it helps you.
It is discontinued, so you will most likely need to buy a new adapter as it is unlikely that there is a 64-bit driver available. Make sure that any adapter you buy has Vista 64-bit support. Try the following google search: "64-bit USB to serial adapter"
You can not use the Belkin Wireless G USB Adapter for the XBox 360. You must buy a USB Wifi adapter that supports the Xbox 360. (See Microsoft's USB WiFi Network Adapter)
