SanDisk Sansa  c200 MP3 Player Logo
Posted on Mar 05, 2011
I need a charger - SanDisk Sansa c200 MP3 Player
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
325
Points
7
You can find it on Amazon: http://www.amazon.com/Rapid-Wall-Charger-Sandisk-Sansa/dp/B000LTLI42
1helpful
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Need battery charger
You could try to buy a charger from Polaroid, but not only will that be expensive, it could be almost impossible to find the same one you had.
I do use two universal chargers, for my camera's. mine are from GP, but I'm convinced there are other brands to. One charger, I need to adjust the spacing between the contacts, but not tree are chargers, that don't need any adjustment. The voltage needed, is found by the charger, the moment you connect the battery.
Because I do have a Kodak (3,7V) a Canon (3,7 volt) and a Nikon (7,2 volt) I have to adjust, but all batteries are charged every time.
When traveling I only need to take one charger for 2 or 3 different cameras. Next camera? I can leave the charger in the box.
same could go for you too.
3answers
Charger problem how to identify
Hi, to identify charger. You will need to test another charger on the cell phone and test that same charger on another phone to confirm if the charger is working.
Also after testing for the charger and and if the charger works, that means the charging port of the phone where the charger is been inserted is damaged.
It will need to be fixed.contact you local repair person for help.
Take care.
May 22, 2011 • Cell Phones
I am needed to find a replacement charger for a wahl rechargeable clipper Model # 8552 It says that it need to be a PCC charger only. Need to know where and how much it would be.
i need a wahl replacement charger PCC as well!!! if anyone knows how to get on let me know because Wahl No Longer sells the clippers so they don't sell the charger now! that sucks wahl !! they should be able to sell you the charger when the charger goes bad like mine did ! it had a short in it and i accidently threw it away!!! now i don't know how to find a replacement charger?thanks
3helpful
2answers
Need battery charger for robust 18v drill/driver. charger model 9706
need battery charger for robust 18v drill/driver. charger model 9706
I have exactly the same charger with the battery .
my drill is fallen , and it is broken .
Jul 13, 2010 • Drills
Ultrastinger Rechargeable Flashlight with DC Car Charger/Holder: charger lite will not come on! there is power to c...
Most likely a short in the charger wiring, try to find someone with another light like yours to confirm, if so you will need to buy a new charger. it coild also be a short in the flashlight charging port too, you will need to confirm with another charger.
1helpful
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
