Question about Paragon 8145-20 Defrost Timer
What is the purpose of the solenoid. - Paragon 8145-20 Defrost Timer
Posted by kenlewis2780 on
Anonymous
You posted under Paragon 8145-20 defrost timer
The solenoid resets timer, and ends defrost cycle when pressure or temperature switch calls for termination.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8145
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 05, 2011
1976 hd fxe shovel... Does the positive cable from the solenoid go directly to the battery or the relay first and then the battery?
There are usually at least three connections to the starter solenoid - two are generally physically larger and designed to carry starter current. One of them will be connected to the starter motor and the other connected to the battery.
Depending on the circuit, if the relay is a starter relay its purpose is to provided the current to energise the solenoid and will be connected to the smaller terminal.
Oct 04, 2018 | Harley Davidson Motorcycles
Is a pollak solenoid 111-257 d,, a continus duty and how many amps
What car is the solenoid on and what is its purpose?
May 22, 2015 | Cars & Trucks
What makes myCub Cadet LTX 1040 not get gas?
It is a fuel shut-off solenoid. Its purpose is an anti backfire device. Its likely the carb is just dirty as opposed to the solenoid failing. But if it has failed it is about $70-$100 to replace. Test the solenoid by removing it from the float bowl and plugging the wire back into it and holding/ grounding it against the crankcase, lock the brake, and turn the ignition key on. You should see the plunger of the solenoid suck in with key on and release with key off. If the solenoid works properly clean/ rebuild the carb. If not working properly clean/ rebuild the carb ( the same stuff that caused the solenoid to fail is still in the carb) and replace the solenoid.
Sep 02, 2014 | Cub Cadet Garden
What the purpose for transmission solenoid 2000 buick lasabre
Which One
Transmissions have 5 to 9 solenoids
They control the trans fluid pressures & shifting
& more
Aug 20, 2014 | Cars & Trucks
What is the purpose of the circuit board onside the starter?
The circuit purpose is to control the operation of the internal solenoid. The circuit board senses the aircraft system voltage during the starting cycle and engages or dis-engages the starter accordingly.
Sep 10, 2012 | Champion Sport & Outdoor - Others
The cold water will not work. All hoses are hooked up correctly, and the cold water is turned on.
2 screws on timer console . may be on back side. flip console back and remove two clips. body will set off. on your valve to check try( for test purpose only)switching hoses and wires on solenoid ( if cold comes in now, you know you have a bad solenoid)or check solenoid with an ohm meter.
Jan 31, 2010 | Whirlpool Washing Machines
1998 ford taurus battery seems to work on all lights but ignition just turn key nothing .icant seem to boost it .is there a fuse somewhere
YOU NEED TO FIND THE STARTER RELAY [SOLENOID] AND CROSS POWER FROM THE TWO LARGE POST WITH A SMALL SCREW DRIVER.IF IT CRANKS OVER THEN YOU NEED A NEW SOLENOID,IF IT DOES'NT YOU NEED TO GET THE STARTER REPLACED OR REPAIRED.
Oct 16, 2009 | 1996 Ford Contour
No hot water whirpool awm 321/3
A faulty inlet valve solenoid on the hot water side could be the cause. The solenoids can be tested for continuity using a multimeter or ohm meter. A lack of continuity indicates a faulty solenoid. I am attaching a photo for reference purposes. Hope this helps and best wishes.
Aug 03, 2009 | Whirlpool AWM5145/2 Front Load Washer
Fan fixed but evaporator solenoid keeps activating at times
the purpose of the valve is to de-ice the evaporator and the valve is turned on by a timer usually. in normal operation, the evaporator builds up with ice (that is how water is extracted). when the valve operates, to put it simply, the hot gas is routed to the evaporator and hence melts the ice off
Aug 28, 2008 | Goldstar DH504EL Dehumidifier
Paragon 8145-20 Defrost Timer Logo
126 people viewed this question
Top Paragon Hardware & Accessories Experts
jdthefixer
Marvin
Marvin
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
