2001 chev silverado, fuel gauge read empty when tank is full of gas. also liw fuel light comes on. when tank is half full it reads ok till tank is empty.. what might be the problem???
the fuel level sender is inside the fuel tank, part of the fuel pump assembly. did you or was the tank replaced before??they may have bent the float arm on reassembly . you can buy the sender from your parts supply store .you will have to drop the tank to do this it clips onto the side of the pump assembly. run it almost dry first as the tank is big n very heavy even 1/4 full. you can try to bend the old arm
but its very hard on the "sender" as for level indicator full to empty, think of the shape of the tank narrow at top to widest point in the middle (full to half) wide middle to narrow bottom( half to empty)
If your fuel gauge is showing you in accurate readings this is normal to all vehicles that are not used to fill-up gas full regularly but sometimes the cause of the inacuracy is due to faulty float valve in the gas tank you need to replace it
My Dad had a 1999 Silverado that did the same thing, it's a bad design. You wont run out but keep track of your miles, Then you know how far you can go.
You weren't low on gas - your fuel tank sending unit is failing and needs replacement. It's inside the tank and usually can be replaced without replacing the fuel pump as well - don't get suckered into that.
fuel tank vent could be blocked by mud/pebbles etc, not letting the gas fumes escape while your adding fuel making it overflow, check underneath the car near the fuel tank .. something to start with..
Youre gauge is controlled by a plunger in the fuel tank which is attached to the sensor and the fuel gauge. it sounds like when the plunger goes down half way its either getting stuck down lower then it should. Needs replacing. Any mechanic can do this install for you.
check the grounds on your fuel tank sending unit,must drop the tank to do this. with the tank down,remove the ground and look at your fuel gauge it should read full or empty,if it does not it may be a sending unit
