Dishwashers Logo
Posted on Mar 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher dispenser will not open. I've been using the detergent tablets and am wondering if I should be using a liquid or powder instead?
Anonymous
Level 2:
  • Expert 77 Answers
  • Posted on Mar 05, 2011
Anonymous
Expert
Level 2:
Answers
77
Questions
Helped
69906
Points
165
Try starting a cycle without using detergent at all. If the dispenser opens, you just need to use powder detergent because the tablets are too big for the dispenser. If it still doesn't work, replace the dispenser. Go to the link to see how to take the door apart and replace the dispenser.
http://www.appliancerepairlesson.com/2011/01/29/dishwasher-soap-cup-dispenser-replacement-dishwasher-repair/
Good luck
www.ApplianceRepairLesson.com
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
709
Points
Hi. We had a similar problem and the cause was very simple. The cutlery in the cutlery rack in front of the detergent dispnser was too tall and so when the dishwasher was closed, the cutlery was blocking the opening of the dispenser door.
My Asko DW20.3 fills up the drip pan with a serious leak that happens when the wash cycle runs. How can I find exactly what is leaking and are parts available to repair this machine?
QUESTION: I just moved into a new apartment. The dishwasher is running normal but when it completes the wash cycle, my dishes are not clean and the detergent tablet is still there. The dishwasher is not dissolving the tablet. Maybe a little bit but about 80% of it is still there. I believe it gets hot water and runs normally. The apartment management said to use dishwasher cleaning tablets and not the powder soap. What can I do to try and get the tablet to dissolve? Any help you can provide would be great!
ANSWER: If your dishwasher hot water temperature is below 110F/115F, then it may not be hot enough to dissolve certain brands of detergent tablets. Be sure the water is HOT before you run the dishwasher. Run the hot water in the sink until it is very hot, then immediately run the dishwasher. Run the dishwasher on the longest, hottest cycle it has.
Also check that the spring opening action of the detergent dispenser door is working properly. If the detergent dispenser is too small a big detergent tablet may not be letting it open correctly. It may be jamming up the door. Try using a liquid or gel dish washing detergent if this is the case. There are many high quality liquid and gel dishwasher detergents on the market today. Liquid Cascade seems to be the best so give that a try. A powdered detergent will work too. Use a rinsing aid also as this will help remove spots even when the tablet may not be dissolving properly.
KEEP THE DISHWASHER DETERGENT DISPENSER CLEAN
If you are in an apartment, then most likely you do not have a high quality dishwasher. Knowing this, the dishwasher needs all the assistance it can get with the hottest water possible. You also need to be sure your dishwasher is clean at the bottom (removable strainer filter) where the pump and bottom washer arm is located. Be sure that it is clean and has hot water and this will be the best method to dissolve tablets. If you must use tablets, you can break them in half in the sink first. Place them in the dispenser and the hot water should make it easier to dissolve since the tablet is not as large.
You also need to be sure there is enough water for the pump to actually pump the water. To check this, start the dishwasher. Once you hear it running, open the dishwasher and be sure there is hot water and enough of it. If there is not much water in the dishwasher it may not be getting much water to the pump. When you open the door while it is running, check the water level at the bottom of the washer. If there is not much water at the bottom, then it may not be getting enough water to clean dishes and dissolve the tablet. Clean the filter at the bottom of the dishwasher to help the pump get the water more efficiently.
DISHWASHER PARTS IDENTIFICATION
If all else fails, you may have an old worn out dishwasher. The pump may be bad. Possibly your water heater is set to low. Your water heater should be set right around 120F. This will ensure that your dishwasher is getting the correct water temperature to effectively clean dishes and dissolve the tablet. If in an apartment, let the management know you are having this issue and they SHOULD resolve it.
Do you know of another way to assist a dishwasher to dissolve a detergent tablet? Please leave a comment below.
Detergent dispenser doesn't open
There is a solenoid in the detergent dispenser that opens at the appropriate time to let the door open and drop detergent. The solenoid might be faulty if the door spring appears alright. One option is to stop using the powder detergent and switch to tablets. One tablet like Finish diamond in the cutlery basket does wonders.
Not sure if you can buy the dispenser to replace.
2answers
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
2answers
How can i use the liquid soap inside the dishwasher
just fill the same holder that you would use for powder.
Dec 17, 2010 • Dishwashers
2helpful
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
5helpful
2answers
Powdered dishwasher detergent stays stuck in dispenser after wash
There is a rather delicate mechanism which controls that soap door. Often this is the first part of a dishwasher to cause trouble. Instead of using the powdered detergent in the soap holder just pour the measured amount into the floor of the machine.
Once you have used up the powder, you might wish to consider a tablet which also just gets tossed.
Sep 18, 2009 • Dishwashers
1helpful
BOSCH DISHWASHER SHU33A DETERGENT DISPENSER WON'T POP OPEN
try some liquid detergent, somehow these powder and tablets tend to stick in and keep the door shut...
7helpful
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
The cover of detergent dispenser does not open..
switch back to using powdered soap, sometimes what happens is hte tablets your using are actually to big for the dispensor door and too much pressure is put againt the actual door so when its triggered to open there too much resistance nad cannot open, sounds silly bu have actually sen it in action. and liquid detergent tends to clog or gunk up hte door spring assy, powdershte best detergent to use for d/w's
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
