If its the lid or removable pot by a very cheap 6 Quart or 6 to litre Slow cooker / Crock pot of the same shape and the removable pot and lid should fit. That's what I did when I broke the lid off my Tricity TSC09 6 litre Slow Cooker I bought a cookworks signature 24 euro 605 litre oval dog standard slow cooker and the lid fit, now I also have a removable pot replacement too in case a smash that too at a low price.
I have a Tricity TSC09 6 litre Slow Cooker and I just love it its so handy. I smashed the lid and was so gutted I tried for hours online to find a replacement lid with no luck. I went shopping and bought a very cheap 6 to 7 Quart or 6 to 6.5 litre Slow cooker / Crock pot of roughly the same size shape the removable pot and lid fit. I bought a cookworks, signature, 24 euro 6.5 litre oval dog standard slow cooker and the lid fit, now I also have a removable pot replacement as well just in case I smash that too. Try that its a cheap option if it a good slow cooker and you cant get spares. You can always bring it back to the shop if it does not fit.
I have a Tricity TSC09 6 litre Slow Cooker and I just love it its so handy. I smashed the lid and was so gutted I tried for hours online to find a replacement lid with no luck. I went shopping and bought a very cheap 6 to 7 Quart or 6 to 6.5 litre Slow cooker / Crock pot of the same shape and the removable pot and lid fit. I bought a cookworks, signature, 24 euro 6.5 litre oval dog standard slow cooker .Now I also have a removable crock replacement as well just in case I smash that too. Hope this helps if you cant find spares and have an expensive slow cooker.
This is an error code for a slow drain or no drain at all problem. It can be due
to a clogged/kinked drain hose, blocked drain filter/coin trap, or a
broken drain pump. The link below provides the detailed troubleshooting
procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs. Error Code E20 on Frigidaire Front Load Washing Machines
Check the incoming water to the dishwasher. If the filter is clogged clean it and re fix. Strainer is located on the machine inlet junction where the hose is fitted.
The humming sound is due to motor running without water. When you rectify the inlet flow fault, pour additional water manually into the wash chamber and run the cycle. This to remove trapped air in the pump due to dry run.
Believe it or not in this day and age, although seemingly wasteful, it is much cheaper to simply purchase an entirely new unit instead of the cost of a replacement liner and the S/H.
