Cisco SG 300-52 (SRW2048-K9-NA) 52-Port Gigabit Managed Switch Logo
Anonymous Posted on Mar 04, 2011
Cisco SG300-52 SRW2048-K9-NA, can you plug in all 52 ports at the same time? Each combo mini-GBIC port has one 10/100/1000 Ethernet port and one mini-GBIC/SFP Gigabit Ethernet slot, with one port active at a time. Issue is some of the ports seem to be not working, not transferring data.
Anonymous
Level 1:
Scholar:
  • Contributor 44 Answers
  • Posted on Mar 05, 2011
Anonymous
Contributor
Level 1:
Scholar:
Answers
44
Questions
0
Helped
35886
Points
73
The 'combo' ports can be ethernet or GBIC, not both. While the ports do provide flexibility for interconnects, they do cause some confusion when this comes up. If you need more ports, some Cisco switches do support 'stacking', where they can be interconnected via their StackWise ports located on the back. These switches work together and act like a single switch. Configuration is generally easy, with one switch being marked as 'master', generally the switch that has the uplink to the rest of the network.
  • Anonymous Mar 11, 2011
    Budget wise getting a switch that does stacking will cost you. If you are on a budget and need more ports, just get another cisco 300 series switch. Create trunks ports (on these series switches you have to make them "general" ports) on each of the switches and connect them together. But you are pretty much scraping the bottom of the cisco barrel with these series switches.
Anonymous
Level 1:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 17 Answers
  • Posted on Apr 21, 2012
Anonymous
Contributor
Level 1:
New Friend:
Teacher:
Answers
17
Questions
0
Helped
14261
Points
16
Dear,I work for Ingellen Communication Equipment and we are a large
fiber optic equipment manufacturer in Shenzhen.Kindly let me know your specific requirements so that i can help
Huawei GE optical port with 1310 SFP module can connect to Cisco 3750X GE ports with GLC-LH-SMD?
The Cisco switch will probably err-disable the port when you plug it in. The workaround is to add these commands:
Switch(config)#service unsupported-transciever
Switch(config)#no errdisable detect cause gbic-invalid
It'll either work or it won't!
tip
Popular Cisco 1900 Series Routers Including Cisco 1941/K9, Sepcial for Mother's...
Cisco 1900 router series including CISCO1941/K9, C1941-SEC-SRE/K9, CISCO1941-SEC/K9, CISCO1941W-A/K9, CISCO1941W-E/K9, etc. are designed for small office and small enterprise branch offices, delivering high-performance, highly secure connectivity with multiservice integration that can transform the workplace with a broad set of services, rich-media support, and operational excellence.
Key features of Cisco 1900 series in detials:High Perfomance: Cisco 1900 series routers offer significant performance improvements over previous-generation ISRs such as 1800 series.
Investment Protection: Cisco router 1900 Series reduces deployment costs and increases flexibility. The platform also offers investment protection with support for a majority of existing WICs and HWICs.
Services On-Demand: The Cisco 1900 Series Integrated Services Routers reduce total cost of ownership by decoupling the delivery of software from hardware on optional service modules. In addition, you receive a Universal IOS image capable of enabling all of Cisco's rich IOS features and allowing you to quickly deploy new services.
Energy Efficiency: The Cisco 1900 Series architecture incorporates higher-efficiency power supplies with intelligent power management.
Specifiction of Cisco Router 1900 series:* Embedded hardware-accelerated VPN encryption.* Secure collaborative communications with Group Encrypted Transport VPN, Dynamic Multipoint VPN, or Enhanced Easy VPN.* Integrated threat control using Cisco IOS Firewall, Cisco IOS Zone-Based Firewall, Cisco IOS IPS, and Cisco IOS Content Filtering.* Identity management that uses authentication, authorization, and accounting (AAA), and public key infrastructure.* 2 Integrated 10/100/1000 Ethernet ports.* 2 enhanced High-Speed WAN Interface Card slots that can host 2 single wide or 1 double wide and 1 single wide (e)HWIC.* Fully integrated power distribution to modules supporting 802.3af Power over Ethernet (PoE) and Cisco Enhanced PoE.
Overall, Cisco 1900 Series Routers offer unparalleled total cost of ownership savings and network agility through the intelligent integration of security, wireless, and application services.
After knowing more information about Cisco router 1900 series, it's nice choice for you to select one of Cisco 1900 series that meet yor need in net to net.Why not choose? More tips about Cisco products and other Cisco network equipments you can visit here: http://www.router-switch.com/Price-cisco-routers-cisco-router-1900-series_c16
on May 05, 2011 • Computers & Internet
How can I download purchased items on itunes (error 8003) from behind a Cisco RV220w firewall?
Configure the Cisco to "log everything", and then try the iTunes download. Then, examine the log-files, to see which connections were blocked. Then, configure the firewall to "allow" those TCP-ports.
Default password for a Cisco SG200-26? cisco, cisco do not work .. ??
I had the same issue after what I thought was a succesful reset. It turns out I hadn't reset the switch completely. There is a reset pin hole next to the power switch. Hold it in with a paper clip for at least 30 seconds. ( I was holding in the power button for 30 seconds.)Then you can use the cisco admin and cisco for password defaults. Hope this helps someone in the future since I spent WAY TOO MUCH TIME on it :)
We have a Linksys SRW2048 48-Port Gigabit Ethernet Switch. The problem is, that we can't get a connection on the 8 ports on the very right side. What could be the problem, how can we solve it?
Disconnect all the Ethernet cables from all the ports.
Connect one of those eight "bad" ports to your laptop.
See if the port works when it is the ONLY active port.
If not, move the cable to the next of the eight "bad" ports, and test again. Repeat.
Move the cable to one of the 40 "good" ports, and test.
If it works, then you have a hardware problem with that "group" of 8 ports.
Your choice to use only the 40 "good" ports, or to replace the router, if you need those last 8 ports.
I have a linksys SRW2024 24 port switch I am trying to run multiple linsysE3200 wireless routers off of it. For some reason they will not connect to the internet.
This isn't a basic switch, it's effectively a router that you must configure it accordingly: a long process in which you must log it and do all the necessary adjustments, starting with the IP assignations for the other routers and the ports settings. The entire process can be found in the manual, Chapters 3 and 4 If you need the manual
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2048/administration/guide/SRW-US_v10_UG_A-Web.pdf
2answers
How to configure mini-GBIC port
For mini-GBIC ports you have to set the media type under the interface settings
if you want to use fiber, set the meida type as fiber and for copper media type as rj45
2answers
Network card
Yuo need to install a driver for your network card. Go to the IBM WEB site to download a network driver for your particular model ThinkPad.
WS-GS5486
If you have device A connected to device B over a Gigabit link, and the link does not come up, perform this procedure.
Step-by-Step Procedure
1. Verify device A and B use the same GBIC, short wavelength (SX), long wavelength (LX), long haul (LH), extended wavelength (ZX), or copper UTP (TX). Both devices must use the same type of GBIC to establish link. An SX GBIC needs to connect with an SX GBIC. An SX GBIC does not link with an LX GBIC.
2. Verify distance and cable used per GBIC as defined by Cisco.
3. If either device has multiple Gigabit ports, connect the ports to each other. This tests each device and verifies that the Gigabit interface functions correctly. For example, you have a switch that has two Gigabit ports. Wire Gigabit port one to Gigabit port two. Does the link come up? If so, the port is good. STP blocks on the port and prevents any loops (port one receive (RX) goes to port two transmit (TX), and port one TX goes to port two RX).
4. If single connection or Step 3 fails with SC connectors, loop the port back to itself (port one RX goes to port one TX). Does the port come up? If not, contact the Cisco TAC, as this can be a faulty port.
5. If steps 3 and 4 are successful, but a connection between device A and B cannot be established, loop ports with the cable that adjoins the two devices. Verify that there is not a faulty cable.
6. Verify that each device supports 802.3z specification for Gigabit auto-negotiation. Gigabit Ethernet has an auto-negotiation procedure that is more extensive than the one used for 10/100 Ethernet (Gigabit auto-negotiation spec: IEEE Std 802.3z-1998). When you enable link negotiation, the system auto-negotiates flow control, duplex mode, and remote fault information. You must either enable or disable link negotiation on both ends of the link. Both ends of the link must be set to the same value or the link cannot connect. Problems have been seen when you connect to devices manufactured before the IEEE 802.3z standard was ratified. If either device does not support Gigabit auto-negotiation, disable the Gigabit auto-negotiation, and it forces the link up.warning.gif Warning: Disabling auto-negotiation hides link drops or physical layer problems. Disabling auto-negotiation is only required if end-devices such as older Gigabit NICs are used which cannot support IEEE 802.3z. Do not disable auto-negotiation between switches unless absolutely required to do so, as physical layer problems can go undetected, which results in STP loops. The alternative is to contact the vendor for software/hardware upgrade for IEEE 802.3z Gigabit auto-negotiation support
Gbic
Hi from the command line interface you will need to login and then type enable (enter) configure (enter), interface fast ethernet all (enter), no shutdown port (port #). Here is a link to the CLI manual if you need more help: http://www116.nortel.com/docs/bvdoc/baystack/doc_pdf/217152-A_CLI_Guide_for_Ethernet_Switch_325-425_Release_3.5.pdf Let me know how it goes or if you need more help. Regards
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
