Gigabyte 845pe (GA-8PE800PRO-R) Motherboard Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mm, my PC didn't turn on and I open de case and I coul see that it had a lot of dust and I cleaned and then It turn on normally. But when I turn on the Pc doesn't detect the netword card, so I can't enter to Internet . I need the drivers for the P4 Titan Series GA-8PE800(-L) Intel 845PE chipset . Thanks Pd: I'm peruvian, so my english is not very well but I guess is clear :D Thanks a lot
NewScrnName
Level 2:
New Friend:
  • Expert 37 Answers
  • Posted on Mar 04, 2011
NewScrnName
Expert
Level 2:
New Friend:
Answers
37
Questions
0
Helped
12261
Points
106
If you have an OEM network card that you installed yourself, then we'll need it's make and model.
If you're referring to the onboard LAN functionality built into that motherboard, it's a Realtek 8201BL PHY
If you have another computer that you can download the drivers on, and then bring them over to this one by usb, you can download the drivers for your motherboard's built in network port from the website below:
http://www.centuso.com/realtek-8201bl-phy
Anonymous
Level 3:
Guru:
  • Master 767 Answers
Anonymous
Master
Level 3:
Guru:
Answers
767
Questions
0
Helped
188089
Points
1958
Just go here.
Under the heading Option 1 select Motherboard in the first box. Then Socket 478 in the next box. Then Intel 845PE in the next. Then GA-8PE800-L in the last.
Click Search.
From the results click Drivers.
Choose your operating system.
Then download the LAN driver for your network card (Realtek 81xx)
Anonymous
Level 2:
Scholar:
  • Expert 80 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
80
Questions
0
Helped
21837
Points
282
I suggest you download the chipset utility from intel then download it from another computer to a USB. then once you have it. you can run it to your original printer and check the type of Driver you would need.
the only thing you can do is use a USB and use another computer for you to get the driver you need.
Also, make sure that the network card is attached securely as well. try to remove it and plug it again.
hope this helps.
My husbands blood pressure is 100/30 is that normal
Lo recomendable es tener una presi?n sist?lica que no supere los 120 mm y la diast?lica siempre por debajo de 90 mm. Por tanto, una tensi?n arterial ?ptima ser?a la que se encontrara por debajo de 120 mm y por debajo de 80mm. La tensi?n arterial normal generalmente se encuentra entre 120 y 129 mm en la sist?lica y entre 80 y 84 mm en la diast?lica. Cuando los valores son iguales o superiores a 140 mm y a 90 mm, nos indica una tensi?n alta o hipertensi?n. Si por el contrario son valores iguales o inferiores a 100 mm y a 60 mm, se trata de una tensi?n baja o hipotensi?n.
Machine E520/windows vista shuts down unexpectedly
If it can be booted up normally after a short while it is most certainly an overheating problem.
Buy an air spray can at the computer store, and if you care a lot about your pc also an antistatic-schock bracelet.
Open the case and clean out all the dust, check if all fans are still working and replace if needed.
My comptur no power
Try to open your pc case and clean the dust of the power supply its the big box with a lot of cables in it.. Try to take the cable out and again switch it in..
1helpful
2answers
Error code on Bosch washer
Just fixed the E:27 error code. Just turn dial to off and hold down delayed start button and spin selector button and turn dial to the left one click (cold). It should then click and open. open the door and turn back to off. Everything should go back to normal. this is something that should have been in the manual.
1helpful
Turned on power button, heard it start up then sounded like paper getting caught in fan,thenpoof and had burning smell,unplugged.looked at rear of tower and saw nothing(no paper in fan) would not turn on
That sounds really bad. You might try opening the case and looking for burn marks. I'd bet you will find lots of dust too. Maybe a careful cleaning operation will help, but it sounds terminal.
1helpful
2answers
My cpu overheats
clean the cpu cooler slots and replace the thermal compound on the cpu ....make sure you clean off the old thermal compound .....only a thin layer of new thermal C will do all most see through ... hope this helps my friend
1helpful
L'eau coule à terre au lieu de couler
hey moi aussi ca coule de par en dessous. je n'ai pas eu le temps d'investiguer ca... c'Est pas tres pratique de prendre l'Eau dans l'aire et la mettre sur le sol. laisse moi savoir si tu a trouver une solution.
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
5helpful
2answers
Turn the power off and on again
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
