Question about Sony Playstation 3 (PS3) Console
My ps3 hangs and then shuts down with a blinking red light. It does this in the hard drive format screen(the one you reach after 2 beeps) as well. So I don't know what the problem is, can anyone help?
Posted by maxdbowman on
James Smith
    Sergeant:
  • 387 Answers
It sounds like its a overheating issue or a bad HDD. Make sure that the console is in a well ventilated area and not confined area. Let me know if you have more info so I can help further. We can start a live chat also as I am a premium expert.
Posted on Mar 04, 2011
When I go to turn the PS3 on, the light goes on but then it goes back to a blinking red light and beeps and just repeats this process.
The blinking red light on PS3 is known to occur when something as simple as a misplaced connection occurs. It could also mean that the PS3's hard drive is malfunctioning or not functioning at all. You can take the following steps to identify and perhaps correct the problem. Check to ensure that all cables are properly and securely connected. If this doesn't solve the problem, try reinstalling the hard drive as indicated below.
Physically remove the hard drive from the PS3 console. Dust off the connectors, and gently and carefully replace it into the PS3. Very often this simple removal and replacement will fix the blinking red light problem. It may be necessary to remove and replace the hard drive several times.
If this does not work the blinking red light can only be inicative of a chronic overheating problem and will nead to be sent to sony for repairs.
Hope this helps
Feb 28, 2011 | Video Game Consoles & Games
Playstation 3 (PS3) Console: Whe i touch the red startup button it beeps and tu...
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro.
http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
May 17, 2010 | Sony Playstation 3 (PS3) Console
How do i fix error 8002f1f9
1. reset ps3 to defaults using recovery menu. 2. begin installation using the same fw version. (hard disk must be formatted externally if u get error 8001002b)
3. when it hangs @ 73% or whatever. Shut down and remove the drive
4. begin the installation of the system inserting the drive into another ps3
5. after it reboots, press (PS), at the disclaimer shut down, remove the drive and put into the broken ps3
6. boot normally...it ask to format the drive...
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
I downloaded playstation home, but when I try to log onto it, it goes onto the loading screen, then auto-shuts off my ps3 system. it beeps three times then my power lighting is the just blinking red...what...
take out the hard drive and then put it back into the ps3. Then turn the system back on and see if the red light goes away.
If the red light is still coming on then that means the hard drive is bad and would need to be replaced.
Nov 28, 2009 | Sony Playstation Home
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
Downloaded update, next day I got the blinking red light
Mate if you turn your PS3 off when the hard drive is still operating or the power shuts of while playing a game and the PS3 is collecting or writing data to your hard drive, it will most definitely corrupt or even destroy your hard drive it is very common in PC's to.
Hint:
1. Do not shut down your PS3 while it is saving a game or collecting info from the hard drive. Rather quit the game then press your off key with one quick touch and let go of it, it will shut down when it is ready or hold down on the remote's PS button and select switch off system on screen.
2. If you live in a area where the power shuts off for no reason please please get your self a computer UPS(UN-INTERRUPTED POWER SUPPLY).
3. If you replace the hard drive make sure you buy a good quality hard drive like a Western Digital or Seagate.
Sep 06, 2009 | Sony Playstation 3 (PS3) Console
Carried out an update, but now stuck in loop
Procedure for Entering Safe mode when PS3 is caught in update loop:
When you first turn on the PS3, it will not allow you to go into Safe mode. You must prepare it for this.
link for flash drive prep:
http://www.us.playstation.com/Support/SystemUpdates/PS3/pc_update.html#update_PC
(This will not work for the drive that currently is caught in the update loop. You must take the hard drive out of the PS3 and temporarily replace it with another 2.5” SATA drive. Note: temp drive may need to be initialized… Connect drive to pc, right click on My Computer and select Manage… Then select disk Management… you will then be presented with a dialogue box that will assist in initializing the disk.. However, only initialize it… Do Not Format it!(waste of time) Once the disk is initialized disconnect it from external enclosure or shut down computer and remove disk)
From the top:
1.) Plug in PS3 and flip switch in back of PS3 to on. Red LED in front of PS3 should light up. Also, plug in Controller at this point.
2.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then a final beep and the PS3 will power off again and Red LED will be on
3.) Hold finger to I/O button on front of PS3 – Green LED lights up
a. You will hear one beep, then another single beep, then two beeps
4.) As soon as you hear the two beeps, hold PS button on Controller
a. You will then be presented with an options screen
i. Restart System -- leads back to update loop
ii. Restore Default Settings --
iii. Restore File System -- leads back to update loop (8002F14E)
iv. Rebuild Database --
v. Restore PS3 System --
vi. System Update -- will cause error
5.) You will then remove the temporary SATA drive from the PS3 and replace it with the hard drive that is caught in the update loo
6.) I am currently stuck attempting to Restore Default Settings and Im sure it will end in error, but i have to try all possible solutions.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Blinking red light
General hardware failure. Usually the red light means either bad power supply or bad hard drive.
You can start by pulling the hard drive out and then power on the system.
More than likely it's a power supply / motherboard issue, in which case you'll have to contact Sony for repair.
You can reach them @ 1-800-345-SONY
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
I left my ps3 on all night with a movie on pause, and now I can't get it to do anything. I took the movie out and shut the system off for a while and every time i turn it back on the screen is black. what...
I the hard drive might have overheated if you didn't have your system near a fan or source of cool air. Try unplugging the unit for a few hours and let it do a self master reset, and then turning on the unit and see if the hard drive reboots.
Jul 23, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
