SOURCE: Image qulaity problem in fujifilm finepix fd50
It sounds like the resolution on the monitor may be set incorrectly in Photoshop. Try a different monitor setting. Twelve megapixels may result in your monitor "seeing" so many pixels it tries to ignore the excess ones, resulting in an image that looks poor on your monitor. If you order one print, that may give you an idea of the true printed quality without spending a lot of money on a bunch of bad prints. The F50 is truly an excellent camera and gives super images, from my experience.
SOURCE: take best possible photos of
Do you have duplexer? try this site
download the user guide
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=110&prodTypeId=18972&prodSeriesId=84028
pls dnt 4get to rate this thanks
SOURCE: how to transfer internal images to sd card?
Put memory card in camera, power up, go to menu and find copy option, select it and press ok.
That will copy picture files from internal memory to memory card.
SOURCE: fujifilm finepix f40fd
An update to the initial posting. As a warranty service provider, I can state that physical damage as a result of mis-use is NOT covered under warranty. Lens problems caused by dropping the camera are considered mis-use and are not covered. There is a good posibility that the lens assembly is just out of timing and can be rebuilt, but the cost to do this will not be paid by the manufacturer.
I don't want you to believe that this repair will be for free as it will not.
Regards,
Dan
SOURCE: my fujifilm finepix s1500 tells me there's a read
i have the exact same problem it works again when you erase the memory card i think its nont the actual memory card but a general camera problem ive tried both my sd 8 gb card and sdhc 16 gb card and both have the same problem
Hi a_milbrodt, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Let us know if the following video steps fixes it:
https://www.youtube.com/watch?v=wlXSt2ef...
