Question about Samsung CLP 315 Laser Printer
Red light is on. It is not blinking, it is solid on. no paper jam, all doors are closed. I took the cartridges out went back and force with them, and put them back. Help !, the warrenty just expired last month, well done Samsung.
Posted by heike_eichho on
MJ'S Computers .Unlt
    Habit-Forming:
  • 85 Answers
If there is no paper in the printer the red light will stay until you put some on it, make sure that when putting paper it goes all the way until the end and the red light will turn green, then you can print.
Posted on Mar 05, 2011
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Samsung ML-2510 Duplex Option Malfunction
    It seems like your duplex is giving you the paper jam issue.
    you may try going to the back of the printer underneath the back door you will be able to locate a tray. that's the duplex. pull out the tray and check is there any paper jam. if not it is most likily that your duplex roller has worn out. (Time to replace the duplex) or you may try to use an eraser to rub the roller put it back and see it helps.
    hope this help :)
    SamsuTech
    Apr 23, 2009 | Samsung ML-2510 Laser Printer
    Samsung printer ml 1510 red light flashes after self test
    Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
    • Printer paper is jammed inside your printer.
    • A cover is not be closed properly.
    • The toner cartridge is not inserted properly and needs to be reinstalled.
    • The toner cartridge is running low.
    • There is no paper in the paper tray.
    • The paper inside the paper tray is not be installed correctly.
    Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
    If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
    You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
    Mar 21, 2009 | Samsung ML 1510 Laser Printer
    Canon MF3240 Paper Jam - No Real Jam
    try this
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
    Failure to print
    Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
    J
    Aug 29, 2008 | HP DeskJet 932c InkJet Printer
    Epson Stylus 440, solid light on for black ink, have replaced and still won't print
    This morning I was researching to purchase a new printer to replace the 10 year one. The last cartridges I had purchased were from Printpal and made in China. They looked the same, but I had to force the door closed on them. With the solid red light on and replacing the cartridge three times with new ones from this order, it was time to find an old used cartridge from another company that I intended to refill myself. I did, installed it and the solid red light disappeared. The old Epson Stylus 440 is still ticking! However, I had written off InkGrabber for unused cartridges going dry in 2 months and now Printpal is on my $%%# list for non-uniform replacement cartridges as well as not lasting long. I am back to refilling my own. I had followed the instructions for resetting the ink level indicator, but to no avail as those instructions are for a blinking light, not a solid light.
    I appreciate your website, if for nothing else, to be able to vent. Thanks so much for your follow-up inquiry and I'm sure you'll hear from me again soon about my old Epson.
    Shirley
    Aug 17, 2008 | Epson Stylus Color 440 InkJet Printer
    Paper Jam
    hey, give this a try:
    alternative :
    Jul 25, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
    Flashing light
    Here is what HP has on the subject of the triangle light flashing:
    c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
    c00028328.gif Door open, media out, no print cartridge, or media jam
    The printer is in an error state that requires operator intervention or help. Check the following:
    • The print cartridge door is completely closed.
    • Media is loaded.
    • The print cartridge is correctly installed in the printer.
    • There is no media jam.
    Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
    13.JJ.NT JAM IN TRAY X
    The Attention LED is blinking. Check paper loading then open and close top cover.
    When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
    When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
    If the light pattern is different let me know (other lights on as well)
    -Hope this helps.
    May 28, 2008 | HP LaserJet 1012 Printer
    All lights blinking
    Try:
    1. Power Unit off
    2. Open front cover
    3. Press and hold GO and turn power on
    4. When all 3 lights lit release and press GO twice
    5. All lights turn solid
    6. With all solid, press GO 5 times
    7. Ready light GOes red
    8. Close door and you're all set
    May 05, 2008 | Brother HL-2040 Laser Printer
    Paper jam
    hey, give this a shot
    alternative :
    Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
    Samsung CLP 315 Laser Printer Logo
    1,036 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
