Question about Car Audio & Video
Car will turn over and wont crank at times - Car Audio & Video
Posted by lancperkins on
Anonymous
    New Friend:
    Problem Solver:
  • 7 Answers
Your alternator isn't charging your batter and needs to be replaced, your battery no longer holds a charge or doesn't have enough cranking amps for the application and that only applies if you aren't playing your music without the motor running. If you play music without the motor running it's going to drain your battery, sure, it'll still play music but the amps will be too low to turn the motor over fast enough to catch the timing on the motor in order to start it. Winter is hard on batteries as well, that's why they have cranking amps and cold cranking amps.
Posted on Mar 04, 2011
Driving car on freeway heard a ping car dies out. Car wont turn over. Changed gas fuel in in gas tank, still wont turn over, changed the crank shaft sensor and still wont turn over but the is getting gas...
turn over or run
turning over is cranking but not starting/running
not turning over indicates seized motor , bad battery starter motor problems , bad ground
turning over is cranking but not starting ---broken timing belt/chain, crank/cam position sensors , no fuel , no spark , no injector operation
best run the fault codes as the fauty will be recorded there
Feb 19, 2018 | Cars & Trucks
I change the angine on my 07 honda civic and it wont crank
this could be a myriad of issues. go back through the wiring harness an check connections. also check timing belt to make sure valve timing is correct. there is a cam AND crank sensor on that car and if the timing is off one tooth itll cause ignition issues.
Nov 14, 2013 | Honda Civic Cars & Trucks
Truck wont start
sounds like the tumblers are worn out get a new or used ignition switch and replace.
Feb 17, 2013 | 2001 Chevrolet Silverado 2500
99 mitsubishi mirage just died as i was driveing. now wont crank, sounds like timing is off. Any suggestions
If the car dies like you flipped a killswitch and wont even try to crank the motor I would definitely lean toward the ignition switch in the steering column is fried. Once it shorts out the car dies and wont crank.
Aug 27, 2010 | 1998 Mitsubishi Mirage
Timing belt wont tutn on my 2005 pt cruiser 2.4l
Try turning the crank with a socket and a bar. is the tensioner making enough tention
Apr 18, 2010 | 2005 Chrysler PT Cruiser
Car wont crank
Turn key on & off five times in a row. Wait 30 sec. & try again. If it doesn't start wait ten min. with key on & start car.
Sep 05, 2009 | 1998 Chevrolet Cavalier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
