Question about Bosch 24 in. PIE675T01E Electric Cooktop
When I switch on, there is a pad lock symbol that gets displayed and I can't turn up the heating elements.
Posted by palurisuresh on
sparky d
    New Friend:
  • 30 Answers
Thank you for using FixYa. The pad lock symbol is a child safety device to prevent accidental operation. Press or touch the area on or around the padlock symbol and the indicator will go out and thus allow you to use the hob
Posted on Mar 04, 2011
  • Jane Wales
    Jane Wales Jul 25, 2014
    On our model HEN3305 Ceramic Hob this is only part of the story - there is a touch sensitive manual override to the front centre hob - we had to deactivate this first before the 'key lock' made any sense.
ERROR BL IS COMING UP WHY IS THIS?
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
Jan 04, 2016 | Cooktops
Main oven does not heat at all
Sounds like the heating/starter element went out. This item is very delicate and will break if touched. They are used on almost all newer gas appliances. It takes about 3 minutes to check. Turn the oven on and look down near the burners with all of the lights in the room out. You should see a glow for a while, then it will click off for a while and then come back on. If not, then turn off the oven and get a flashlight and look for the starter element to see if it is broken. It is about one inch wide, two inches long, and 1/4 inch thick. If you do get a glow then this is good news, the element is not broken. However, the element operates a thermostatic switch which operates the gas valve. This switch may be broken. The switch and the starter element usually come out together when removed.
Jan 13, 2014 | Thermador PRL486EDPG 48in Pro-Grand LP...
UNLOCK THE LOCK OF CHILDREN IN CERAMIC
Hi and welcome to FixYa,
I can not insert the symbols here to properly answer your question so, I found the manual and you can read the steps on page 9 here:
http://awadnahas.net/pdf/UserManual/bf7e9e9b-cc9e-46fc-94a7-5965a2d61b18.pdf
This is copy and paste from the manual and the symbols will not come out:
Switching off the child safety device
• Start the hob with ( ' ). Do not set the heat settings . Touch for (Up arrow) 4 seconds. The
symbol ( 0 ) comes on.
• Stop the hob with ( I )
The symbols I typed above are not 100% as they appear in the manual.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | AEG HK955070CB 41 in. Electric Cooktop
Wolf Induction cooktop is locked in Showroom mode
May 01, 2010 | LG 30" Built-In Electric Induction Cooktop...
My Kenmore Range had theoven and stovetop locked symbol on it how do i unlock it
Either hold down the 'Unlock' button or if the little red pad lock symbol is lid in the main display hold the 'Oven light' button for about 7 seconds...
Jan 18, 2010 | Kenmore Elite 44173 30 in. Electric...
I have the 5 element induction cooktop with no
Call 1 800 442 1111 Its whirlpool they own kitchenaid. they can find a local tech for you
Dec 12, 2009 | Cooktops
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
May 14, 2009 | Jenn-Air JED8430 Electric Cooktop
Got a diplomat ceramic hob with no instructions
If the KEY lock is on (key botton flashes when switched on) ... touch AND HOLD the lock symbol for AT LEAST TWO seconds until it beeps, then hold the on/off button for AT LEAST 2 SECS.
If the CHILD lock is on ([L] on all displays when switched on), then:
1)Hold the on switch for TWO secs min (unit swtiches on) ...then
2) touch AND HOLD the + AND - for AT LEAST 2 secs
3) touch the - button once again.
Jan 14, 2009 | Cooktops
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Cannot turn on cooktop.
I have a Kenmore Elite Induction Cooktop and we had some milk boil over and now the cooktop is locked. How do you unlock it?
Aug 30, 2007 | Smeg 24 in. SE2663TC Electric Cooktop
Bosch 24 in. PIE675T01E Electric Cooktop Logo
1,670 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
ray gallant
Steve F
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
