Question about Haier BC112G Wine Cooler
It just stopt cooling ([email protected]) - Haier BC112G Wine Cooler
Posted by wgersdorf on
Wale Sarumi KomputerSolution
  • Haier Master
  • 6,993 Answers
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Posted on Mar 04, 2011
What means error 49.2348?
If you wish to get some details; check the site linked here. Pull up older posts....
http://electro-medical.blogspot.com/
May 02, 2016 | Office Equipment & Supplies
Cod p0460
P0460 - Fuel Level Sensor Circuit Malfunction
Possible causes- Fuel Level Sensor harness is open or shorted
- Fuel Level Sensor circuit poor electrical connection
- Faulty Fuel Level Sensor
- Faulty combination meter
Read more: http://engine-codes.com/p0460.html#ixzz26lL9SePi
Sep 17, 2012 | 2004 BMW 7 Series
Needle is not going down, hard to turn the weel on a side? it just stopt sewing. how can i fix? thanks
try these sites & see if they have any video's on the problem
youtube
ehow
fixsewingmachine.com
Apr 15, 2012 | Sewing Machines
Fireplace will not start. I have not had it lite since last winter. I turn to pilot and wait then hit ignite. I get a spark but the pilot light does not light.
your line mite be stopt up get a mach and turn on you gas and see if i lights up if it dont your eather out of gas or your gas holes whare the flame cums out is stopt up
Dec 16, 2009 | Blue Flame Charmglow 30K BTU NG Vent Free ...
My synaptics touch pad stopted working
Go to http://www.synaptics.com/support/drivers
Locate your operating system and download the driver.
Works like a charm! (I've used with several brands of laptops as well as OS's from Win98 to XP)
Enjoy!
Nov 16, 2009 | Compaq Computers & Internet
Can someone help pls my hp dv6000 fan stopt working the one above the proccecer and i dint notice this untill i turnd it on and melted a wee bit off the plastic above the fan becouse of the heat strain...
dirt **** and old age is the reason for fan failer
replace the fan then turn on the computer again make sure if the fan has 3 wires you replace it with a 3 wire as it monitors fan speed
Jul 25, 2009 | Computers & Internet
Water leakeg from front top part of the engine above the cooling circiut pamp at begininig of the operation it stopt after worming up
If this is a 5.2 or a 5.9, there is a hose under the A/C compressor bracket. You can't see it until you remove the bracket. It goes from the water pump to the intake.
Mar 28, 2009 | 2004 Jeep Grand Cherokee
Lambda Sensor or Air Mass Meter?
replace the temp sensor in the thermostat housing behind alt(2 wires)
Aug 08, 2008 | 1999 Volvo V70
Haier BC112G Wine Cooler Logo
992 people viewed this question
Top Haier Furniture Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Haier Furniture Expert? Answer questions, earn points and help others
