SOURCE: audiovox battery charger Rbn-300
If you remove the 4 screws to the top of the RBN-300 battery holder, then separate the halves, you will see a small IC board charge controller in the top 1/2. Remove the 3 screws to it, gently remove the board & (with a magnifier) look at the contact to the side of the board from the power plug (close to the LED light.
If you wiggle the low volt power plug, I expect you will see that the solder joint has broken on the board edge. Resolder & reassemble -I use hot melt glue to help support the plug to avoid re-breakage between plug & board.
This may fix your problem unless the erratic circuit connection has killed either the control board or you battery.
BCinBC
SOURCE: Audiovox D1705
Audiovox has a replacement battery (Item # 02MN0103B) for $55 including ground shipping:
http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13134&langId=-1
SOURCE: Replacement battery for Coby TF-DVD7005 DVD Player.
need a coby rechargeable batt pac. Where can I get it and how much is it?
