Question about Whirlpool Washing Machines
The status light says "control
Posted by g_tumlinson on
Anonymous
    New Friend:
  • 30 Answers
Thank you for using FixYa. The " control locked " is a safety feature to prevent the inadvertant use of the machine by a child. To unlock the controls press the "end of cycle "button for approximately 3 seconds until the "control locked " indicator light goes out. If you have young children in your home and want to lock the controls press the "end of cycle" button again for three seconds.
Please post if this solution has been helpfull
Thank you
Duncan
Posted on Mar 04, 2011
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
Cannot be started and the status light "control
Take a good look on the control panel on the right ..It has a button that says press for 3 seconds for to lock ..Im not sure on your model ...but all models have a control locking button ..It may be the start cycle one ..If it is ..you have to press he button for 3 seconds and will unlock the controls ..
This happens when you try to make it start the cycle and hold the button on ..too long ..
Aug 15, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The "Control Locked" light is
Mar 31, 2011 | Washing Machines
How do you remove the control lock when the "end of cycle" button didn't unlock it?
Instructions below:
To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off.
To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The controls locked is displayed. what causes this and how do i get the controls unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
My "Control Locked" is locked. What do I do?
Select and hold the end of cycle button for 3 seconds until the control locked status light goes off.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore He2Plus Washer: Controls Locked button lites up & beeps
plug it back in and there should be a buttong somwhere toward the corner and in small lettering"un-lock/lock" hold that button for 5 secs and see if it un-locks the board. if it dont the your board might be bad....hopefully this helps
Jul 30, 2009 | Washing Machines
Washing Machines Logo
61 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
