Question about Bunn B10 Coffee Maker
Light in the rocker switch for warmer is blown. Switch works; Warmer works can it be fixed got the pot in 03 (b10b)
Posted by Janet Sowell on
Anonymous
    Scholar:
  • 64 Answers
It's an easy fix. If you're handy with a soldering iron, you can get a replacement switch (in your choice of colors - think about that!) at any electronics store, perhaps even Radio Shack. It's best to remove the old switch & bring it in to be matched.
If you're not so handy, I'd look around for one of the old, disappearing "mom&pop" electronics shops that you can still find in strip malls. These guys are happy for your business, and have decades of experience. They can do it for you.
If you bring it into a shop, you can save some money by tearing the coffee maker down first (and putting it back together yourself). Otherwise, you're paying them an hourly rate to do what you yourself can do.
Posted on Mar 04, 2011
I have a bunn 11 the problem im having is sometimes it works fine and other times the machine will turn on and off. I unplug and replug it works then continues to flicker on and off. Any sugestions.
There is a ready light (green but sometimes red) that will go on and off as the brewer heats up. It will periodically turn off when re-heating but should light when ready. This is normal.
* Bunn have red rocker switches that are sometimes lit when in use. Some do flicker but still work. Call for service if not.
* Rocker (RED) switches should have a definite click sound from the switch. these are usually the warmer plate or on/off switches. Some may flicker but you can check the warmer plate if it's working. Ask the vendor to change it the next time they come by as it still works but annoying.
* The black rockers (unlit) should snap to all EXCEPT the brew switch which tends to be mushy with a spring back. The only way to know if it works is the plate gets warm.
* Check the outlet if any other machine shows intermittent power. Some places overload the outlet and trip the breaker or GFRI so frequently most people unknowing think the power blacks out all night but really someone just reset the breaker. Have maintenance move the brewer on another outlet (and breaker) or have the breaker checked as it may be worn.
* Call your vendor anyway as there may be an electrical short or loose wire inside the brewer. Many times I've found the warmer plate wires burnt or fell off the terminals.
Aloha, ukeboy57
May 16, 2017 | Bunn Coffee Makers & Espresso Machines
My warmer plate light does not work and the water in holding tank feels warm on top not on bottom,coffee is not hot enough to dissolve powderewd creamer.Why?
No warmer plate llight:
Usually means bad switch. Bunn Part no. is 20316.0001. Replacement available at link below.
Bunn Home On Off Warmer Control Switch Lighted
Note differences in switch wiring in photo below between old and new style switches.
Coffee not hot:
Make sure "Vacation Switch" is in OFF position.
Aug 07, 2014 | Retail Supplies
How do I make coffee with a Grindmaster Pourover Coffee maker?
COFFEE PREPARATION PROCEDURES
1) Place filter into brew basket.
2) Put the proper amount of coffee into the filter.
3) Slide the brew basket into holder.
4) Place empty decanter on warmer located directly under the brew basket and turn corresponding warmer switch ON.
5) Pour decanter of fresh water through pour-in opening at top of brewer.
6) Hot water will be delivered through the sprayhead. This distributes the hot water evenly over the coffee bed within the brew basket. The coffee will drain from brew basket into the container below.
7) Red light indicates warmer is ON.
8) Before brewing next pot, remove brew basket from brew rails and dump filter into waste basket.
Please rate this a fixya
Feb 08, 2009 | Grindmaster Pourover Brewer - 18
Red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Nov 24, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
8543 not working
CHECK THE BLACK WIRE COMING OFF THE BOTTOM TERMINAL OF THERMOSTAT FOR VOLTAGE, IT SUPPLIES POWER FOR THE WARMER SWITCHES. THE 'READY TO BREW' LIGHT IS PROBABLY A BAD BULB.
Oct 12, 2008 | Bloomfield 8543 Coffee Maker
I did the initialization as per the directions and the water was hot. When I make the coffee, the warmer button will not come on and the coffee is cold. I turned on the vacation button for 15 minutes...
Sounds like something is miswired from the factory. Note that the tank heater switch on most home brewer models also acts as the "master" power switch. If the tank heater switch is not on, the warmer switch will not work, either - this is normal. Under normal conditions, the tank heater (or vacation switch) should always remain on, except if you are leaving on vacation.
Apr 18, 2008 | Bunn NHB Coffee Maker
Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Apr 05, 2008 | Bunn NHB Coffee Maker
Warming plate boils coffee.
Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
Feb 08, 2008 | Bunn VPR Coffee Maker
Does not brew a full pot of coffee
1) Unplug the NHB
27) Empty pot.
Oct 29, 2007 | Bunn NHB Coffee Maker
Bunn B10 Coffee Maker Logo
293 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
